Tsonic650 , 2GBwas not sensed by USB , after tryng for formating
RECYCLE VIRUS, was on my mp3 ,that was blocking all folders , to solve that problem I tried to format using the CD given by Transend, it got locked now it is not being recognized by USB ,even on two different computers , desk top and laptop, also tried with different cables , I did a reset ,still not helping. It shows T sonic v 1.3, now after 4 hrs ,it is blank screen. I have just bought 3 weeks back in India now I am at Eritrea ,north east Africa pl. help me to enjoy ur MP3 , Tsonc 650, which I raelly liked its versatality om FM, Music , Voice recording etc. Thanking you
Re: Tsonic650 , 2GBwas not sensed by USB , after tryng...
Its a software problem....download the firmware from http://www.transcendusa.com/Support/DLCenter/Driver/MP650FWV1.65.zip the press reset button for 2 seconds and then connect to system while pressing volume - button..run the updater and click on search devie..follow the instructions in the attached file for more details
It is possible that the memory was damaged or is infected with a strong virus malware that does a block on detection to the PC. try the same on another PC which has a good protection and if this works there are faults on your port or the PC is infected.
If the drive is still not detected then the memory is faulty even after you try to format on any PC.
i can only offer you to use latest version of "ESET NOD32 Anti Virus". because i know only this anti virus which can delete this virus. you can download it from here: http://www.scanwith.com/download/NOD32.htm
Dear Sir, There is one problem to my Compaq Laptop it is that when i click on any of the icons then it show the option i.e( Are you sure you want to remove the folder and move all the contents to the recycle bin) and it goes to recycle bin. yesterday i have already done a formatting of my laptop and i have also installed Quick Heal anti virus. please send me the option to solve critical problem.
You need to do a low level format on the pen drive and the system drive. I have found by using programs like kill disk is the best way to get rid of a worm virus. A regurlar format will not work, unlike what they say to you. Kill disk will stop all running prorgrams on the drive. What it does it rights zero to the pen the drive. After that you need to do the same to your system drive. Otherwise you will be back to square one.
Suddenly my centon 4GB wasn't allowing me to add mp3s to it as it said
it didn't have any more space but I knew it did because I had just
deleted a couple gigs. I figured out that there's an "invisible"
recycle folder on the mp3 player that has the files you've deleted
still stored in it.
To fix do this:
1. plug your mp3 player into the USB port.
2. Find out the letter of the drive it appears as.
ex. let's say the external drive it appears as is F:\
3. Now go to:
Start
Run
Type in: F:\recycled
4. Click on File on the top toolbar
5. Click Empty Recycle Bin
Your free space on your mp3 player should now successfully be retrieved!
your pedrive contains {Autorun} virus that's why you are unable to format it to view this virus go to view option in control panel then view and tick the show hidden file and folder
you can remove this virus install malwarebytes and scan your pendrive when you remove the virus format your pendrive
IF it not works I think you use windows xp that's why it happen
you need to reformat that, just right click your unit and go to format and click Quick format,, because it is an TROJAN virus that will destroy the format of each system so needed for reformating, just follow the step what i command
hope it can help it to you pls rate it!! thanks
