Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Flashing green timer light
I have a 4 year old Mitsubishi WD-52725 which has been giving us lots of problems...very disappointed with all the maintenance issues and costs incurred to repair...paid $4061.00 for the TV and then the replacement lamps are $225.00+ which you need to do after 2 years. The second lamp only lasted 7 months and we were not watching this TV more than before. I now have the blinking green timer light on and have tried to reset several times, left the TV unplugged overnight and nothing seems to work to stop it. You cannot turn the TV on while the green light is flashing. I contacted Mitsubishi Digital Electronics American Inc.- emailed to mdeaservice@mdea.com and reported my numerous problems. They have given me a file number and asked that I fax them my estimate to repair with proof of purchase and they would then review and let me know what out of warranty assistance they can extend to me. I would gladly join a class action suit and hope everyone with problems emails Mitsubishi at the above email address. After paying so much for a TV, one would hope it would last longer than this.
  • phaze9868 Aug 01, 2009
    I did have a repairman come out and pick up the TV to repair - he is sending chassis to Mitsubishi. I received a call from Mitsubishi and they are picking up all costs except the labor which is going to run me approx $250.00. This TV has a beautiful picture - just too bad so many problems with it.
  • 668 Answers
The Chassis Assembly will need to be sent to Mitsubishi for them to refurb. I would estimate the cost to be 850.00 to 900.00. A Authorizes Service Facility would have to confirm this.
Hope this helps.
Skyassoc
Posted on Jul 17, 2009
  • Steve Yocum Aug 03, 2009
    I am happy for you that Mitsubishi is willing to help out on the cost. They too have skin in the game to retain customers who are faithful. Although this chassis has had it's issues, it does have a wonderful picture and performs well when running correctly. Not to let Mitsubishi off the hook too much, it was also one of the most sophisticated / high tech DLPS on the market at the time and they had no idea of the coming problems until 3 years or so after manufacturing the chassis. By then they were already 3 to 4 generation of chassis down the road.
    I hope you are able to enjoy using your set when it is repaired for many years to come.
    Steve,
    Skyassoc
    Sniper:
  • 53 Answers
There are 2 potential solutions.
SOLUTION 1: Success guaranteed
One is, correctly stated, that the electrical chassis assembly be sent to a qualified rebuild facility. Total P&L cost on the rebuild is more realistically around $400-$500. However, if you involve a repair technician to remove the chassis and reassemble--then--yes, you are looking at an additional $200-$300 in labor costs.
The chassis on your set is located on the left (if you are facing the set from the rear). You will need to remove the back cover of the set, including the lamp door. You will then need to remove terminal shield (3 screws on either side, attached to the support bars) and a host of screws on the terminal face itself (where your inputs are).
The chassis is held in place by 2 screws into the base and one at the top. The chassis will slide out, but you will need to remove quite a few connectors in order to free it up. This chassis holds the majority of PCBs for the set, including the power supply. The power supply is located at the front of the chassis (the end furthest into the set). You will need to remove the shield of the power supply to disconnect the ballast cables. Some people suggest you can snip these ballast cables, but I usually just take the extra 10 minutes to free them up.
Now, chassis is free and you can send it off. Please make a note of all the cables you send with the chassis, as if any are misplaced in the repair process, you can make a case for getting your wires back.
SOLUTION 2: Success Possible
In order to attempt this repair, you still have to remove the chassis.
Once removed, you have to completely disassemble the chassis, freeing most of the printed circuit boards.
There are 4 capacitors on the DM board and 4 capacitors on the FMT board that are known to "vent." Capacitors should have a flat top. If any are tented or raised in the center, those capacitors are bad and need to be replaced.
I have fixed a few of these infinite green timer light issues by replacing the 8 caps on the FMT/DM board.
If you are handy with a soldering gun, you could try and tackle it yourself, but give yourself 4+ hours to completely disassemble and reassemble the chassis and boards.
If you have a repair guy do this, you are looking around $400-$500 total. However, be aware that sometimes those capacitors are not enough and will necessitate a rebuild. A halfway decent repair company won't double hit you on the labor and just charge you for the parts and one round of labor.
Posted on Aug 01, 2009
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
My tv does not come on.A green light is flashing above my timer button. No picture.
The green light flashing is an error code. Count the number of flashes and it will tell the issue. Write back once you've counted the flashes. Also, was the TV having any issues before this? Was there a recent storm or power surge?
Oct 20, 2010 | Mitsubishi WD-52725 52". Rear Projection...
My WD-52725 Projection TV will not turn on. The
Where is the reset button on a 65 CD Mitsubishi HDMI TV
Jul 08, 2010 | Mitsubishi WD-52725 52". Rear Projection...
I have a Mitsubishi WD-52725 Projection TV. I
Call MITS, and try to get a tech to assist. Green timer flashing is "waiting for CPU to boot". Normally 70 seconds after plug-in. If doesn't stop, then not booting, and you won't be able to turn on. It only boots after being unplugged.
Apr 22, 2010 | Televison & Video
What repair is needed for blinking green light and
These sets had a lot of problems like yours---for a while lots of them had 3 different boards with caps going bad etc---a real nightmare---fix one board and a few months later another goes out.
I was at a local Mitsubishi authorized repair center recently---Because of all the problems there is now available an ENTIRE CHASSIS exchange for most of these sets---it wholesales for about 200---a third of what it will cost you to have a shop fix all three of the suspect boards.
This is from what I was told a response by Mitsubishi from the THOUSANDS OF ANGRY PEOPLE WHO PAID A LOT OF MONEY--and 3 or 4 years later the sets are dropping like flies.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Timer light is flashing and I cant turn on tv
The V26 DM repair kit should take care of that issue. The kit has the caps and the instructions. You can get it at www.tvrepairworld.com
Aug 03, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi Model WD-52725 timer green light blinking fast
My Mitsubishi WD52725 will not turn on...the timer light is blinking. We pushed the reset button, unplugged tv. Just got off the phone with Mitsubishi customer "service." After answering numerous personal questions, and being on hold for several minutes, I was told that the only solution was to push the reset button. Duh! We'd done that several times with no change, which is why I called them! BIG WASTE OF TIME!!!!
Nov 08, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
633 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
