Question about Rangemaster Kitchen Ranges
My rangemaster has an LPG hob. recently it seems to be burning a yellow flame which is leaving a soot residue on my pans, it is not as hot as before either, can you help?
  • 1314 Answers
SOURCE: Cannon Rhapsody LPG Gas open Fire sooting up of burners
well its my experience that ranges don't come lpg they are all made natural gas but you convert them to lpg after purchase now if the lpg conversion isn't done properly then they soot like crazy proper lpg converson is to change the spuds on the burners and to turn the orifice over in the pressure regulator do you still have your owners manuel if so consult it on converting gas range to lp then check to see if every thing was done right on the pressure regulater there is a square cap you take it off and there is a round part that on one side says lp on the other says ng this changes the pressure that the regulator as ng and lp operates at different pressures and the regulator has to be set for what you using like i said im not familiar with your brand or model but i do know the problem if the range did come ng then you need to make sure the conversion most ranges aren't lp because there is not that big a market for it read the plate on the back will tell you if it was made ng or lp serial plate on front may say also most of the time it is beside the bottom drawer on the range
Posted on Jan 18, 2008
  • 6 Answers
SOURCE: oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Posted on Dec 20, 2008
  • 95 Answers
SOURCE: Kenmore gas stove. Oven burns big flame which soots
The manifold needs to be cleaned and adjusted could have rust etc in it Not a good thing to do yourself unless you know what you are doing
Posted on Jan 24, 2009
SOURCE: RANGEMASTER 110 Cooker FLAME FAILURE DEVICE fitting
the ffd comes has a unit with a gas tap connected to it. can be brought for £90.99 from manufactures.
Posted on Feb 20, 2009
jumptrout51
  • 3361 Answers
SOURCE: can you convert any natural gas hobs to LPG?
They are convertible. Most come with converting parts attached to the interior of the range.
Posted on Feb 21, 2009
My stove has a yellow flame and some burners leave soot on pans
perhaps you are using the wrong type gas natural does not burn as hot as Propane .
Jun 16, 2016 | Kitchen Ranges
Flame on main hob of range master 110 is yellow and smelly also black sooty deposit left on jets
Ream out all the orifices and air venturi holes on the burner, adjust the air-ahutter, the air-shutter is usually nearer the valve/knob than to the burner. Yellow flame is an imbalance of fuel to oxygen and is creating Carbon Monoxide and not burning cleanly... this is the same problem that can make a furnace deadly. Blue flame=neutral flame.
Apr 25, 2016 | Rangemaster 110 (Gas) Kitchen Range
Are Propane LPG fryers compatible with Butane LpG
Talk to the manufacturer or check your owners manual. The jets in the burner must be slightly smaller for butane. The flame will burn yellow with black soot/smoke if you don't change them.
Jul 24, 2014 | Pitco Frialator Kitchen Appliances -...
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
When one of the gas hobs is on ,it does not burn with a blue flame but a more yellow one .also black soot forms under the burner plate.it is on lpg
Have to adjust the piolot lights for the amount of gas coming out. U have too much gas coming out(yellow flame). On older gas ranges, there was a small screw between the piolot light & burners that had to be adjusted. (if this is a older model) have to turn the screw just a little at a time, till ur flame returns to blue on ur burners. Hope this helps.
Sep 12, 2010 | Microwave Ovens
I have a new gas hob which is making the bottom of my pans black like soot?
You must have an improper air/gas ratio. To adjust the shutters you simply open or close them a hair till you get a beautiful blue flame. Improper flame is yellow, good flame is blue. 9916a1c.jpgThis gas conversion training manual shows where to adjust
Apr 22, 2010 | Cooktops
How to fit a flame failure device to rangemaster 55
the part that you need is the oven ignitor, located nest to the oven burner. that part gets hot to open the gas to the burner, that will make the oven work again.
Dec 08, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Had a new gas hob installed but two of the gas burners only have a very low flame even when turned to high. One of the others has yellow flame tips even on low and is leaving marks on the bottom of the...
propane or natural gas? if it was converted inproperly it will leave soot on your pans. also you will see flames when you bake with it or broil.
Nov 01, 2008 | Kitchen Ranges
Gas Hob Flame
Hello
Tha sounds to me like the air mixture nedds to be adjusted on the stove, It's not difficult to do, just rotate it until the flames loose the yellow or your pans will be stained with soot.
The should be by the fittings (convertion fittings), you know?
LP Gas to Natural Gas or Natural Gas to LP Gas.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 30, 2008 | Cooktops
Kitchen Ranges Logo
49 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Mike Carew
paulcarew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
