Sony KLV-26BX310 BRAVIA Multiysystem LCD TV for 110-240 volts Logo
a
andrew kiage machuki Posted on Mar 13, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need front panel screen for sony klv26bx310 tv.How much?
THE FRONT PANEL IS BROKEN AND I NEED TO REPLACE IT.
Steve F
Level 3:
  • Master 1,361 Answers
  • Posted on Mar 13, 2016
Steve F
Master
Level 3:
Answers
1361
Questions
Helped
567482
Points
3788
You will need to contact Sont or a Sont Agent. Its probably more expensive than buying a new TV
Need Replacement Front Panel
The Sony KV-36FS100 listed as the model number here DOES NOT HAVE A PANEL--uses a picture tube---if another model/brand let me know.
As far as the broken buttons---they may be available as a unit or not depending on the age of the set.
Getting an original remote would allow you to do without those--if you do not have the original remote (or it does not work) GOOGLE THE MODEL NUMBER OF THE SET WITH "remote" to locate a replacement.
Hannspree notebook lcd screen broken
should be screw on front or back,,if front there under rubber groments,,,pull them up/ off with flat head,,to reveal screws,,
1helpful
How did I correct blue and red lines curved across a blank screen of my KP-57WV600 SONY Projection TV?
This is for if the lines are thin and arc.
You need to turn down the screen voltage for the blue and red CRT. I don't remember if the focus block is in the front or in the back of the tv on this model. Most projections have them in the front.
You could check the back access panel and look for a black box with six knobs as descibed in step 3 below. This is what you are looking for.
follow the steps below if it is located in the front:
1) Remove the front grill
2) There should be access panel you need to remove once you remove the front grill. This is where the screen voltage adjustment is located
3) Look for a small black box with six knobs on it. One row is for "Focus" and one row is for "screen". It will be marked, but probably need a flashlight to see which row it is. There will be a "R", "G" and "B" next to each knob to represent Red, Green Blue respectively.
4) Careful with the access panel removed, you are only inches away from very dangerous voltages.
5) slowly turn the R or B knob counterclockwise until the lines on the screen disappear.
Keep your hands away from everything else and only use one hand near the tv. put the other hand behind your back.
6) Once corrected, replace the panel and put the grill cover back on.
1helpful
2answers
My husband fell into the television and the front screen popped out. Can we put it back in ourselves? It is not broken
You should be able too. You will need a torx #20 driver bit to remove the bezel around the screen. Carefully... The screen can be easly scratched
2answers
I have a SONY KP55WS500 projection tv which has been a great TV. Unfortunately we were rearranging the living room and a bookshelf fell and broke the front screen. I cant find the part because of the age...
No,not repairable,because the front screen panel are 90% of the tv,sorry ur tv now,it only can be salvage for electronic boards for parts,that it.The tv screen panels are only can be purcharse from the tvs corporation themselves.They'll charge u the screen panel the same priced as new tv.Because the tv screen panels are in limited production and 90% improtant to the tv,that why.
Front screen broke,i nedd to replace,how much would cost me.
Sorry,the LCD screen panel is broken or damages.The tv is not worth repairing.Because the tvs LCD screen panels are 90% of the tvs and it limited production by the tvs industries.The replacement of LCD screen panel to the tv,will cost the same as a new tv.Sorry the tv now,don't worth as a whole tv anymore.The tv now,only can be salvages for electronic boards for parts,that it.
2answers
I have a Sony Bravia KDL-32BX300 the screen is cracked and broken where can i find a replacement screen
i have a Sony Bravia KDL-32BX300 the screen is cracked and broken where can i find a replacement screen
1helpful
HAve a 42 Sony Wega rear projection TV. Need to replace Bulb but dont know were bulb is. Do I need to take off back panel?
the lamp is located in front below the screen. there is a plastic panel to remove(full width of t.v.) the lamp is in the center held by allen head screws(replacement lamp will supply an allen wrench) be carefull not to get fingerprints or dirt on front of lamp(premature lamp failure will happen) hope this helps.
I have a sony lcd kdl-52w3000 and it has 2 large circles on the left side of the screen(it can also be seen when the tv is off) and it has 3 small ones on the botom of the screen.
Seems front screen layers got some dust or some thing that you see as big circles.
Need to apart front bazel assembly of TV, remove front screen and clean it carefully because it can be broke easily.
Scratch
hello, if there is a scratch on your reflective outer glass panel screen, it can be replaced if you are handy with tools or diy i happen to have the screen removal manual for this tv model th42pz700u you dont have to dissasemble the tv just the outer front housing remove the back panel and theres some screws that hold the front casing on those come of and the front refelctive glass can be removed without any trouble or dissasembly of the internals just the front casing
you may need to find a selling as is plasma tv with a broken internal screen usually they are this way that outer screen dosent break easily so unless you want to pay 489 for this reflective glass part i would try and find a 'for parts or repair 42 inch pany' they will fit if they are the same size make sure the outer screen is not broken or scratched. hope this help
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
