Question about Car Audio & Video
I have JVC-KD406 car stereo,its malfunctioning.only one single function can be used after reset,sometimes CD that cant be ejected or sometimes it will go off and can no longer be turned on
After reset it will stick to one function,if CD is use after reset,it will only play CD and can no longer be ejected and other functions are disabled like volume,menu,equalizer . Sometimes after reset,it will just put on standby and can no longer perform other functions like volume and others . Please help me on this
  • 883 Answers
SOURCE: CD WONT PLAY
guessing that your laser diode or drive motor or laser sled has stopped working...need more info...
Posted on Jun 01, 2007
SOURCE: JVC KD-SX770
Per manual, you can lock a cd in by pressing and holding the power and cd button for moer than 2 secondsthe cd cannot be ejected. if acd is inserted upside down, please -eject appears.
Posted on Aug 11, 2007
SOURCE: JVC Car stereo with cd shuts off when volume is turned up
Hi Ithink , you are trying to push too much power to your speaker setup. Your cd, tuner, player, is only go as loud as the volume at half way setting. Your speakers are , probally good ones that want more power, and making your player overheat and making circut protection cut power. I would say, you should use it at 15, and that is as loud as it should be played to aviod distortion and overheating.
I'm guessing max is like 25 or 30, Is that so? You can listen to louder tunes by installing an amplifier. Or if you have an amp in your system it may be overheating, I would really like you to let me know if you have been trying use it at volume higher than half the maxium volume setting, so I know I helped, and you can start looking into power amp's. You can crank it up for good parts, but most players were not made to send alot of juice to good big speakers at high volume level.
Tell me what you think, tooldoc
Posted on Dec 05, 2008
SOURCE: JVC CD player won't turn on, but will eject CD and display time.
Make sure the red wire is still connected or make sure the red wire hasn't been severed. Also, check the fuses located in the engine compartment. The red wire connects accessory terminal in the fuse block. Also check the fuses in the cabin. This fuse box is typically located on the driver's side, at knee level, next to the door panel, and underneath the dashboard. As a last resort, the unit can be taken to an authorized or factory service center.
Posted on Feb 01, 2009
  • 108 Answers
SOURCE: system lights up - stuck in demo mode - sometimes CD player plays
if detach face may not be making good contact try removing wipe connections w/rub alchol and put back on
Posted on Mar 26, 2009
Cd not ejecting
Insertion of the wrong type of CD (as specifically identified in the instructions for the car stereo) could have jammed the eject mechanism.
May 14, 2014 | Pioneer DEH-150MP Single DIN Car Stereo...
How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
Feb 02, 2011 | JVC KD-G510 CD Player
Hubby has a CD stuck in stereo and cannot seem to get it out. Will not eject. How do we get it out?
sometimes you can either press a reset switch or disconnect power and it might eject the cd.
Aug 23, 2010 | JVC KD-SX939 CD Player
JVC won't eject my CD!
Turn radio off Push and hold the eject button Turn radio on while holding the eject button.
This is the force eject sequence
Apr 05, 2010 | JVC AM FM CD DET FACE CAR STEREO
My jvc car stereo show eject in the panel a nd
Check wiring. Yellow to Battery, Red to ignition sw, black to ground. Confirm the functions. If everything is OK, then connect speakers, antenna, etc.
Dec 31, 2009 | JVC AM FM CD DET FACE CAR STEREO
Stuck disc in JVC CD player
It wasn't a car cd player, but a component for a stereo.  I took off the case and shook the player until the disc dropped out.  We plan to replace the player, so no further help is needed.  Thank you for getting back to me so quickly.
Jan 11, 2009 | JVC AM FM CD DET FACE CAR STEREO
NEEDS TO BE RESET
the cd have been jam in there you need to open it and take out the cd manualy and that should solve you prm
Dec 15, 2008 | JVC AM FM CD DET FACE CAR STEREO
JVC head unit problem
Do you have a "RESET" button on your stereo? Check your owner's manual to find it. I have a JVC unit in my car and the reset button is a small hole behind the detachable face. Take the end of a pencil or a pen and insert it in the tiny hole and hold for a few seconds. This should reset the stereo so you can get the CD out. Hope this helps...
Aug 28, 2008 | Car Audio & Video
CD Player
I'm currently having the same problem. Take the face plate off. Use a pin to reset the stereo. It'll probably stop working again, but at least you'll be able to get your cd out and take it somewhere to have the stereo fixed or replace. (STAY AWAY FROM JVC!)
May 20, 2007 | JVC KD-G200 CD Player
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
