Question about Maytag MER6772 Gemini Electric Kitchen Range
In a typical baking the heat comes from the top or bottom of an oven?
  • 441 Answers
When set to bae the heat comes from the bottom, the top is on when set to broil
Posted on Jul 16, 2009
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Have just moved from UK and we don't have broil and bake on our ovens - what do they mean/what's the difference as I've been cooking garlic bread on bake but it's taking twice as long to cook?
The broil is the top element and the bake is the bottom element...so with broil you are heating from the top and with bake you are heating from the bottom...if your oven has a fan, turn that on with a bake setting and it will speed up the process..
heatman101
Apr 20, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Top oven not heating up on BAKE, broiler gas and flames come on. Stove top burners work, Bottom oven heats for BAKE and BROIL.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 08, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I have a whirlpool range mod rf368lxpq o replaed probe and panel still very slow to come to temp. pre heat goes to about 200 deg and then veryy slow to come up to temp and hold temp
It sounds like one of the elements are not working. There should be a concealed element in the bottom of the oven and a 'bake assist' element at the top iether seperate from the grill element or as a dual element assembly. Both of these elements should heat on bake function (not the grill element though), check for heat from both by turning bake on and feeling for heat from top and bottom. The oven requires heat from bot to get up to and maintain temp.
Hope this helps
Dec 02, 2009 | Kitchen Ranges
Frigidaire range model #FEFLFSA, is the top element
When you say Top Element, I assume you mean the TOP OVEN ELEMENT, correct? You have bake, and broil? Bake is usually on the bottom, and broil is the top. In order to have the oven operate correctly, the top and bottom elements may come on at start, in order to do as you just said, "Preheat the oven". This will insure an even distribution of the heat in the oven box and result in better cooking expierences. I would not be alarmed or concerned if the top element came on for a short period to pre-heat in preparation for cooking. This is normal. If the top element stayed on, and did not shut off on bake after the pre-heat period, then I would say you have a control board problem. However, if it comes on and then goes out, except when you are broiling, then I would say that this is normal for your stove, and the pre-heat mode of operations. Your owners manual should advise you of this very process in the guide section to how to use the oven. I hope this helps and that all your cakes, pies, souffle's and the like are......delicious. I'm sure they are. I hope this helps and eases your concerns. Kindest regards, Slats.
Sep 25, 2009 | Frigidaire Kitchen Ranges
Bottom oven will not heat up.
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Jun 11, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven heating on bake
yes both elemnts do initially come on to get unit up to temp ( a bake boost) the lower elemnt then cycles on/off to maintain temp.. that is normal operation
Nov 11, 2008 | Kitchen Ranges
Uneven heating in our Whirlpool range
on bake setting only your bake element is on broil element comes on for preheat only naturally the top part of your oven is hotter heat rises take the temp in the center of oven with a good thermometer
those cheap ones are a guide only dont swear by them
Dec 06, 2007 | Kitchen Ranges
Maytag MER6772 Gemini Electric Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
