My Cobra 7600 it keeps turning off when trying to update
I am trying to update my Cobra for the first time and it turns off within seconds of my connecting it to the computer and disconnects the upgrade, it seems only to be working when plugged into the car
Try this program:http://www.softpedia.com/get/Tweak/Unins... and disable automatic updates: START-> CONTROL PANEL-> AUTOMATIC UPDATES -> CHOOSE THE OPTION -> Turn off automatic updates <- ;-)
if you have a genuine copy, make sure your date and time settings are correct and try last known-good configuration if available else repair or reinstall your OS installation
Try this program:http://www.softpedia.com/get/Tweak/Unins... and disable automatic updates: START-> CONTROL PANEL-> AUTOMATIC UPDATES -> CHOOSE THE OPTION -> Turn off automatic updates <- ;-) ....
Try reprogramming the remotes. Here are the instructions for the procedure. Hope it helps. Cobra!
Programming
NOTE: All keyless entry remote transmitters (15K601) must be
programmed at the same time. NOTE: To program (or reprogram) the keyless entry remote transmitters
into the RAP module, perform the following steps:
Make sure that the anti-theft system is not armed or triggered.
Turn the ignition switch (11572) from OFF to RUN eight times within ten
seconds, ending in RUN. If the RAP module has successfully entered program mode,
it will lock and then unlock all doors.
Within 20 seconds, press any button on a keyless entry remote transmitter,
and the doors will lock and then unlock to confirm that each keyless entry
remote transmitter has been programmed. Repeat this step for each
transmitter.
If the door locks do not respond for any keyless entry remote transmitter,
wait several seconds and press the button again. If the door locks still fail to
respond, refer to Inspection and Verification.
Turn the ignition switch to the OFF position, or wait up to 20 seconds after
step 2, to exit program mode. If a keyless entry remote transmitter has been
programmed (or reprogrammed), the RAP module will lock and unlock all doors one
last time to confirm.
Turn off printer Hold PAPER SOURCE+PAPER FEED+CUT/EJECT buttons at the same time and keep them pressed Turn on printer Release buttons Hidden new menu appears press DOWN, “CLEAR COUNTERS” option should appear press RIGHT press UP, “MAINT TANK” should appear press RIGHT press ENTER (CUT/EJECT button) Turn off printer.
The x-band is the considered a "trash band". It picks up things like automatic doors at supermarkets and such. About every radar detector made has an X band for non-police radar. There is no way to turn this band off on the XRS-757.
Holding down the dim button for 2 seconds turns the V alert on/off
Holding down the city button for 2 seconds turns the Spectra on/off
Holding both city and dim together for 2 seconds turns K and Ku band on/off.
Dear sir,
Try to operate in channel 1~7 , keep the maximum range extender button pressed for 5 seconds u will hear 2 beeps sounds. If it works Ok or else u need to change your Radio antennae
