Question about Nokia 6263 Cellular Phone
My Nokia 6263 phone shuts off when it wants to and the when I got it back on Half of my phone numbers were missing then I shut it off again and back on they were all there. I did get and message that the sim card was rejected. Also it start with a full charge and went down to nothing. Then I tried to set it back to factory settings and not it will turn on for about 20 seconds and shut back off also the screen keeps blinking during this time. I have never dropped it nor have gotten it wet. Thank you Denise
Restriction code
You can get the restriction code for your Nokia 6263 phone from SuperUnlockCodes.com here you need to specify your country,Network name to which it is locked,IMEI number of your phone.Then they deliver unlock code to you through mail with unlocking instructions.By using this you can unlock your phone easily.
Aug 22, 2013 | Nokia 6263 Cellular Phone
Nokia 6263 453 error invalid number
try to do factory reset by menu, settings, default code is 12345
Jun 29, 2012 | Nokia 6263 Cellular Phone
Hey can i please get an unlock for my nokia 6263 ntm
Several methods are there to unlock mobile phones among that codes are the best way ...........
Get the unlock code for your Nokia 6263 model mobile from this site Superunlockcodes.com , here get the unlock code along with easy instructions for your mobile.........
Nov 26, 2011 | Nokia 6263 Cellular Phone
Hey can i please get an unlock for my nokia 6263 IMEI# 356958010742361 - it will be highly appreciated if u can do so.
To Unlock the Nokia 6263 model Phone use the Unlock code,get the Unlock code
at
Mobileunlocksolutions specify the Network it locked ,country...
Jun 02, 2011 | Nokia 6263 Cellular Phone
Need nokia restriction code 6263 to block incoming calls
you can unlock restriction in nokia 6263 mobile in simple way using this site www.superunlockcodes.com/nokia-6263.
Nov 02, 2010 | Nokia 6263 Cellular Phone
Nokia6263when i switch it on it shows a white screen and aflickering screen it shuts itself down icant dial or see the numbers besides this it just do things with out a command
There are only three possible cause of the problem:
1. Defective LCD
2. Defective battery or components - if the battery is defective or if there are some faulty components inside, the phone is not getting the right amount of power that it should get. So the phone usually shuts off.
3. Corrupted firmware - once you have a corrupted firmware, the phone might not either work correctly when opening some applications, or it would automatically shut off.
You need to bring the phone to the Nokia Care Center near you. If the phone is under the warranty period, you will not pay even a single cent. However, if it's out of the warranty, the charge is low.
Thank you and good luck!
May 20, 2010 | Nokia 6263 Cellular Phone
Phone won't work without headset
go into the sound profiles and c wat has been set there, sumtimes headset only gets selected, reset or change the profile and c if it works..
Nov 03, 2009 | Nokia 6263 Cellular Phone
I need Unlock codes for Nokia 6263 IMEI: 356985013139268
Phone: Nokia
Model: 6263
IMEI: 356985010258046
Please provide the unlock code to anand_k@rediffmail.com
Jul 09, 2009 | Nokia Cell Phones
Nokia 6263 Cellular Phone Logo
211 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
