Question about Hayward SAND FILTER, PRO SERIES
HOW DO I USE USE THE PUMP TO VACUUM WITHOUT LETTING WATER OUT OF THE POOL?
  • 93 Answers
Put vac with pole and hose attached put other end of hose into skimmer usaully has a plate with stem to attach to if not make sure hose fits tight in skimmer hole turn to filter
Posted on Jul 21, 2009
    President:
  • Hayward Master
  • 1,378 Answers
Your valve should be set to filter when you vacuum, not waste.
Posted on Jul 17, 2009
How do I vacuum my index pool
Even with an "upgraded" pump, it still doesn't provide enough suction to do a good job. They are just a better than non upgraded 'toy'! But... Take your vacuum hose with the vacuum head attached and one end connected to your telescopic pole and send it to the bottom of the pool. Then slowly feed the rest of the hose pushing water into the hose until you reach the opposite end. Water should come out of the other end! If it does not, you did not prime the hose correctly. Try it again this time push deeper into the water beating the hose slowly pushing the water up into the hose at the surface level. Once you have water coming out of the other end you plug it into your suction port. Turn on the pump and now you have section at the other end of the hose, that the vacuum head. Now just vacuum the bottom of the pool, as you would vacuum your carpet in your home.
all of that dirt, sand, silt, and other debris, will end up in your filter element. You will have to clean it, if not replace it.
Feb 07, 2015 | Intex Ultra Metal Frame Pool w/ Upgraded...
What would be the best automatic pool cleaner for intex 18 x 48 easy set
the vacuum you are using is probably the best for the system you have. if you want a REAL pool vacuum, get a REAL pool. there is a reason that these are considered disposable pools. dont get me wrong, any way to cool off is great and these pools allow people this 'luxury' at a reasonable cost but they are assembled with low end, non standardized equipment that doesnt match with traditional pool equipment.
Sep 09, 2014 | Intex 18 ft x 48" Easy Set Inflatable...
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Pump is blowing cloudy water back into pool
Cloudy water is the bane of sand filters!. I suggest letting filter run day and night. Do not backwash until the pressure rises 8 - 10 pounds above clean starting pressure. Do not try to vacuum or stir up the sediment. when water clears, vacuum to waste. Keep the hose running while vacuuming. A dirty filter is a better filter (up to a point). At a higher pressure the filter will trap more of the fine particles that are clouding your water.
May 28, 2013 | Pentair Meteor Above-ground 22" Sand...
The vacuum is not picking up the debris in the pool
if it drives ok, then it should be the water pump motor
if you see the water bubbling at the top of your pool then the vacuum part is working
Jun 25, 2012 | Smartpool Dolphin Robo - Kleen Above...
How do i set up the vacuum for intake pool?
The first thing you need to do is make sure the pump is primed and able to draw water from the pool and return it with full flow to the pool. Now turn it off and make sure that your hose fits into the suction port and that the hose connects correctly to the vacuum head and the pool pole fits to the vacuum head. Next you need to disconnect the vacuum from the suction port and place the vacuum head with the hose and pole connected to it onto the bottom of the pool. Now force the hose straight down into the pool so it forces water into the hose and forces all the air out of the end that connects to the suction port. Keep forcing more and more hose into the pool until all the hose is filled with water. This is called "sinking the hose". The end of the hose can now be connect to the suction port. When the pump is turned on it should start pumping water from the hose into the pump and when flow is able to draw dirt as you move the vacuum across the bottom of the pool until it is clean. I hope this helps.
Aug 09, 2011 | Intex Easy Set Pool 15x36
How do i vacuum my pool yahoo.com
The first thing you need to do is make sure the pump is primed and able to draw water from the pool and return it with full flow to the pool. Now turn it off and make sure that your hose fits into the suction port and that the hose connects correctly to the vacuum head and the pool pole fits to the vacuum head. Next you need to disconnect the vacuum from the suction port and place the vacuum head with the hose and pole connected to it onto the bottom of the pool. Now force the hose straight down into the pool so it forces water into the hose and forces all the air out of the end that connects to the suction port. Keep forcing more and more hose into the pool until all the hose is filled with water. This is called "sinking the hose". The end of the hose can now be connected to the suction port. When the pump is turned on it should start pumping water from the hose into the pump and when flow is able to draw dirt as you move the vacuum across the bottom of the pool until it is clean. I hope this helps.
Aug 08, 2011 | Hayward SAND FILTER, PRO SERIES
There is a 3 way valve that regulates water to the pump from my in ground pool. Is there a way to attach hose and vacuum without repeatedly unplugging and replugging the electrical supply? The suction...
1. My pump has a switch on the bottom of the back of the pump opposite the impellar, check yours.
2. Does the 3 way valve change where the suction is coming from? If so, when done vacuuming through the skimmer, switch the valve to the bottom inlet and skimmer suction should stop if the valve is working properly.
Gary
Jul 12, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Raypak pool heater is making a knocking noise
low water flow check manual bypass in heat exchange if spring broke letting too much water bypass and overheating water in unit also see if pump ok and filters
Jun 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Losing pressure 2-3 min vacuum hose is attached to skimmer
de filters clog very fast i suggest put vac in pool put hose over pool attach a wet vac to get water out of hose remove wet vac and vac saves de and water
Jul 09, 2009 | Hayward 1HP Super Pump II Inground Pool...
Hayward SAND FILTER, PRO SERIES Logo
300 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
