A hunt and count question. core/freezed plug.
NO VIN told no
RPO code for engine told.
8th digit of VIN is ENGINE CODE VIN :"Y" below.
or vin=9 (8TH)
well even the service manual does not do the count.
it shows some, block and heads.
what you can learn to do is google it.
here is how to do that
I google new rebuilt raw engine blocks for sale.
watch out engine can evolve and even be swapped a newer GEN engine, 279 cu in (4.6 L)
but I will post for DAY new,1996 only
1996, the Northstar engine
RPO code
LD8 or L37
lets to LD8
the
DeVille Concours was available with the new 270 hp (201 kW)
LD8 Northstar V8, and later, the high-output
L37 Northstar generating 300 hp (220 kW).
LD8
first hit shows VIN-=Y shows 4 in the 2 heads 2x2.=4
left and right heads outside ends. and 1 rear and front of head for 6 total,
https://www.npdengines.com/product-page/96-99-cadillac-deville-4-6-northstar-engine-vin-y
found with google
die-cast aluminum block!!! SORRY NOT SAND CAST.
A GOOD TECH FINDS THE ACTUAL LEAK FIRST
SEEMS YOU ARE GUESSING,
THE 1995 BACK IS ALL DIFFERENT.
LOTS OF VIEW HERE, ALL FOUND VIA GOOGLING FOR YOU.
https://www.hpmotors.com/cadillac-northstar-v8.html
FIND THE LEAK FIRST, THEN WORRY CORE PLUGS IF AT ALL.
