Help! no manual!
Can't figure out how to change setting to reduce size of picture. Heads are being cut off and can't read anything on bottom of screen.
  • 2 more comments
  • foolishsucka Nov 18, 2007
    Sorry! Sony Bravia KDL-46S2010
    ARC button??? i've gone into menu>settings. the only standard i see is 4 picture; as in standard, vivid, custom.
    still confused. what about changing to pillar box, cropped etc...
    where do i go in menu to do that? will that help?
    thank you! still can't find what i'm looking for. appreciate help! :)
  • jbrice Dec 12, 2008
    I have tried all of the aspect settings but the top and bottom of the picture still are cut off. Is it possible there is another setting to change the image size? Thnaks Jim
I cant set up my playstation3, i already conected the red, white and yellow, i dont know if i have to set up the TV?
Posted on Feb 27, 2009
  • 4,889 Answers
Brnd and model number pls..
Posted on Nov 18, 2007
  • 4 more comments
  • eagle338
    eagle338 Nov 18, 2007
    Its ok.. just keep pressing the ARC button until it comes to standard mode..the thing is that it has several modes such as zoom,wide,standard and stuff..just set it to standard mode..
  • eagle338
    wait the best thing to do will be to find a manual for you hang on..
  • eagle338
    here..Go to this page and click on operating instructions..
    http://esupport.sony.com/US/perl/model-d...
  • eagle338
    I have got to go out now will fix ur prob in the next 5 hrs..
  • eagle338
    Hey its there in the manual.. you have to press the white button repeatedly until it becomes normal..Its on page 21 of the document..
  • eagle338
    Sorry its "wide" button not white..
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Picture on 47
You do not worry at all, because the set is under warranty.
Launch a complaint and sit peas fully.
Jul 23, 2012 | RCA 47LA55RS 47 in. LCD TV
The picture is too big for the screen. how can i make the picture match my screen size?
Posting the model number would make a response more valid but you need to go through the main menu selection and check to see if you can alter screen resolution or geometry there.Most sets offer different views such as 'Panorama,' 'Full screen,' etc.
Nov 21, 2011 | Sanyo Televison & Video
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Picture size is off center
Is this coming in signal is Free air or cables.
If it Free air u can't not adjust sub channels in most stations for screen sizes.
Aug 24, 2009 | Televison & Video
How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
The picture is too large for the screen and cuts off the top of people's heads.
change the reolution Consult the manual for thios or go to setting and choose display and select a different resolution until you find the right one you have not included a screen size or model here try anything higher than 800x600 or panavison
Aug 01, 2009 | Televison & Video
How to adjust pitcher size
Try this setting and see if it helps: Menu>Picture>Advance Picture Settings>Scan Velocity Modulation (Check mark it) Then the TV will try to auto adjust it's picture size to the source you are using. I noticed it most on ESPN News HD. If you are using a HD cable box, you might be able to use the cable box settings to change the picture size. Sometimes the box is on "Zoom" and it takes the top of heads off.
May 25, 2009 | RCA R52WH76 Television
Vertical Stretch
You need to adjust "vertical height" in the service program. You need to put the set in "service mode" to do this adjustment. If you google "enter service mode RCA F32665" you should find the procedure. It will be listed in abbreviated letters such as VERT SIZE or VERT HT. Follow the instructions for entering service mode and saving the data closely!! The data you change will be listed as a number between 1 and 63. The number will only need to reduced by a small amount and you can still see the picture behind the data and watch it shrink as you adjust the number down.Always burn the new number to memory (if required) before exiting service mode. Good luck
barneyluc
Dec 01, 2008 | RCA F32665 32" TV
Televison & Video Logo
704 people viewed this question
Top Televison & Video Experts
