Powers on, sound is fine through cable or DVD, can change channels and play DVD, no picture.started getting fuzzy, for a couple of weeks then just went total black one night. Any ideas? The lamp?
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
replace DM or try to fix it. http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair http://hdtvoice.com/voice/showthread.php?t=32186
had this problem when I start using it with "component" video cables on a new digital wide screen TV. I fixed it through the DVD player's setup menu, by changing the "video output" setting. On my Samsung player there are 3 options: S-video, 525i and 525p. It was set to S-video, and by changing it to any of the other two settings the problem was solved.
