Question about Garden
Pull cord broke on my lawn boy mower,new cord won't retract??
Replaced cord, but i can't get the cord to retract after pullling?...any hints?
    New Friend:
    Problem Solver:
  • 12 Answers
Well done on replacement of cord...but it appears you have not PRE TENTIONED the cord by holding the cord and turning in the same direction as pulling untill some resistance is felt (to pull the cord back in) then it must be held while you thread it through the out let and pull handle and make a big knot! Test to ensure pawls come out to engage with pulley...fit same job done!! Cheers
Posted on May 08, 2016
  • 376 Answers
I don't know exactly what you have there, but starters in general work pretty much the same. What you have to do with any starter when you replace the rope is to first wind up the spring with the pulley. Turn the pulley in the direction it would be turning if you were pulling the rope. When it's wound tight, back off to align the rope hole in the cover and the pulley. Stick the rope from the outside through the cover and pulley and tie a knot. Then let the spring tension pull the rope into the starter. Hope that helps. Dwain
Posted on Jul 16, 2009
How do you retract the pull cord?
if the spring broke you replace the spring usually.
Aug 17, 2015 | Talon Rotary Lawn Mower
Fix recoil when pull cord on sanli lawnmower broke
Take the starter assembly off the mower. Unwind the spool using whatever method works (2 screwdrivers?) until you capture the remaining. cord. Pull it all the way out. Pin the spool so that it can't retract. Remove and replace the cord. Re-assemble. Back to cutting grass!
Mar 15, 2015 | Garden
Pull cord won't retract
Hi Susan. It sounds like the spring has either snapped or become un attached. It's going to be a two person job to re do it. It may be worth while going to a scrap metal merchant and getting the recoil starter of an old mower.
Jul 26, 2013 | Poulan Garden
Starting cord won't retract
if its brand new take it back tell them the retraction spring is broken and fix it
Jul 25, 2013 | Garden
We broke the pull cord and after pulling the cord won't recoil to proper position.
remove the cord assembly ,, either the cord is off track and needs to be rewound or it broke and needs replacement
Jul 16, 2011 | Toro Super Recycler Super Bagger Lawn...
Lawnboy model 10640 walk-behind mower pull cord will not retract. I've removed the plastic engine covering, removed the top bolts of the gas tank and rotated the tank back. With the flywheel cover being...
I have the exact same problem. I read on another site that the blowout hole in the back of the mower where the grass goes into the catcher must be cleared of any grass or dirt. I don't use the grass catcher and indeed the hole was full of dirt and grass. I cleared out what I could with my hands and a screwdriver, and magically somehow the cord retracted about a foot. Enough to start the mower with. It still doesn't retract all the way, but it was an improvement. I may have worn out the spring pulling and tugging on it trying to get it to retract, but ok for now.
Please share if you find a more permanent solution. Mower is barely a year old.
Apr 21, 2011 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Problems with pull cord ,pull cord not engageing,pull cord is slipping freely.it acts like a bad spring on a briggs,but iam not familiar with this make.
Pull cords are all pretty similar so if you've seen one then etc.....
Does the cord retract?
If it's a broken spring then the pull cord would not retract.
If it is retracting then it's probably dirt, grass clipping interfering with the spring loaded locking lever.
Either way the only way to be sure is to remove the top cover and inspect it visually and clean it out and spray some lubrication on it.
You should be able to do this without taking apart the actual cord and retracting coil spring. It should come off as a unit.
Once you have inspected it if you you have any other questions please let me know.
Hope this helps.
Jun 16, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Trying to replace pull cord for kee tm22 push mower. new cord will not retract. replaced with new cord and now cord will not retract when pulled. spring came out while removing old cord but replaced in...
Take off the whole assembly, find and replace the spring, manuually wind up the reel until it is loaded with tension in the direction that will retract the cord. THEN put new cord in through the feedhole then the assembly, then tie a small figure eight knot at the very end of the pull cord, pull it tight so it stays in its recess and then let the cord retract by releasing the tension. - you now have a fully charged retractor assembly. put it on tightly with the three 10mm bolts, reattach the plastic cover and git mowin.
Mar 27, 2010 | Garden
Garden Logo
2,417 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
