Question about ASUS P5GC-MX/1333 Motherboard
How to connect front panel audio jumpers? - ASUS P5GC-MX/1333 Motherboard
  • 565 Answers
Here's the manual download for that board:
http://support.asus.com/download/download.aspx?SLanguage=en-us
The connections for the front panel audio are shown on page 1-32.
If you still have trouble, please post back to this thread.
Posted on Jul 16, 2009
5 Suggested Answers
sri2008
  • 53 Answers
SOURCE: Viper MSNV-939 ATX Socket 939 audio connector jumper settings
 u short the pins with jumpers as per the diag
        5    4     3    2    1
       10          8     7    6
in this u short the   5,10  with one jumper &   3,8 wth another jumper
was this helpful to u, give the rating for me
thanks
Posted on Feb 22, 2008
  • 624 Answers
SOURCE: Blinking Power LED ... no other action
Hi switchblade, Some of this will seem basic or even a rehash of what you?ve already done but please keep an open mind. The one thing I?ve learned over the years is never assume anything especially when things aren?t working like they?re supposed to. -The first thing I would do is to check each screw, card, connector and component you installed to make sure nothings being shorted out or is improperly connected. Common occurrences are screws touching capacitor or other component leads. -Check the power connectors to make sure everything is connected correctly and that all the contacts are still mounted in the plastic connector correctly. -Check the output on your power supply and verify it?s rated for your motherboard. It?s possible that whatever caused them to replace the motherboard could have been caused by a defective power supply or vice versa. -Make sure the motherboard is correctly grounded to the chassis per your instructions. Typically the mounting screws touch a grounding plane on the motherboard and in turn ground that to the chassis. If your using plastic mounting studs that might be a problem. -Verify the power switch is working correctly. -Make this as basic a machine as possible: remove and add in cards (except primary video card), remove all USB components, reduce the size of your memory (RAM) and if you have multiple hard drives remove all except your boot drive. -Try a more basic known good video card, a PCI if you have one. -Again whatever problem caused MSI to warranty replace your motherboard could have damaged your processor or memory. I would have expected a beep code but if you?ve gotten this far without resolving your problem we?re running out of possibilities. -If nothing changes can you tell us some more about the status of the computer or what led up to this? Did you just build it; just install a new part, power problems, anything? Let us know what you turn up and please don?t forget to rate the posting.
Posted on Jan 08, 2007
  • 207 Answers
SOURCE: asus p5pe-vm front panel audio connector (10-1 pin FP_audio)
jumper setting for audio panel? i didnt get tht one
Posted on May 22, 2008
bad_theta
  • 31 Answers
Look this picture below, this is ASUS P4VM front panel.
Hpe its solve your problem....
Posted on Jun 01, 2009
Hi ,, i have just fitted a intel d845gvsrb in my pc but i am not sure where the tower speaker wire , reset sw , power sw , power led , h h d led and the black single one go`s can you please help me ..
The Picture below shows you the locations of the places to put those wires are in relation to your motherboard. In yellow is the power switch and such. and the audio connection is in red.
The Pin layout for the power and other connector are as follows:
the layout for the audio header is as follows: avatar23454_8.jpg
To install the cable that connects a front panel audio solution to the front panel audio header, follow these steps:
  1. Turn off all peripheral devices connected to the computer. Turn off the computer and disconnect the AC power cord.
  2. Locate the front panel audio header (J8A1).
  3. Remove the three jumpers from the header (this disables the back panel audio connectors).
  4. Install a correctly keyed and shielded front panel audio cable.
  5. Connect the audio cable to the front panel audio solution.
To restore back panel operations follow these steps:
1. Remove the front panel audio cable. 2. Install a jumper on pins 5-6 (rear R channel). 3. Install a jumper on pins 9-10 (rear L channel). 4. Install a jumper on pins 1-2 (mic). 5. Replace the cover.
Apr 17, 2011 | Intel D845GVSR Motherboard
How to connect audio from motherboard p5s800
It is Asus P5S800-VM motherboard. Download the manual from Asus, click the link provided;
http://www.asus.com/Search.aspx?SearchKey=P5S800-VM
You'll need to download and install Adobe reader to view the manual;
http://www.adobe.com/products/reader/
Turn to page 1-29. Section 11. Front panel audio connector (10-1 pin FP_Audio1). Notice there are two jumpers. One across pins 9 and 10. Another across pins 5 and 6. Pin one is marked, AGND and pin two is marked MIC2. ECT.
This is default setting when using the rear audio jacks. You can not run rear audio and front audio at the same time. (So pick one or the other). To run front case audio remove the jumpers and connect the I/O cables to the FP_Audio1 pins. There is a work around. You can buy an adapter that will split the audio from the rear allowing you to connect secondary audio and mic ports. Open the link provided;
http://www.cablestogo.com/product.asp?cat_id=2009&sku=40422
You can buy these locally. To connect the FP_Audio remove the jumpers and connect the I/O cable to FP_audio pins. Use Adobe reader and zoom in. You'll find each pin is marked.
Cheers'
Mike
Mar 08, 2010 | Computers & Internet
I want to connect front pannal audio port what are the avialble extra audio connector in d845 epi m/board
Front panel 9-pin audio connection is located at "A" on the diagram. There will probably be two jumpers there - remove them and plug in the audio connector It can only fit one way.170eb7d.jpg
Nov 27, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Audio sound problems
to enable REAR green audio port,there needs to be jumpers between pins 5-6 and 9-10 of J2 which is towards back PCI slot area.If the jumpers are not present, the front panel audio is enabled.
Jun 27, 2009 | Computers & Internet
Speakers no longer work when front panel audio cable connected.
Thats the point of the jumpers. They need to be connected to make the connection so the rear is disabled when you plug things in. Here is where your jumpers should be placed:
Basicly every other bank needs a jumper.
May 01, 2009 | ASUS K8V-MX Motherboard
Asus p5pe-vm front panel audio connector (10-1 pin FP_audio)
F_AUDIO <==> CASE
1- PORT_1L == MIC_IN
3- PORT_1R == MIC_PWR
5- PORT_2R == R_OUT
9- PORT_2L == L_OUT
-------------- OTHER SIDE ------------- (case wire)
2- GND
4- GND (other)
6- R_Return
8- key
10- L_Return
May 16, 2008 | ASUS P5PE-VM Motherboard
Front Panel Audio
I don't believe that this motherboard supports simultaneous front and rear audio. That's the purpose of the jumpers; to route audio to the back panel when on and to the front panel when the front panel connectors are connected,
Jan 13, 2008 | ASUS P4GE-V Motherboard
Frontpanel sound
By default, the pins labeled LINE OUT_R/BLINE_OUT_R and the pins LINE OUT_L/BLINE_OUT_L are shortened with jumper caps. You should remove the caps ONLY when you are connecting the front audio cable. So, if you are going to use the back panel, you should short the pins mentioned earlier. You cannot use the back panel and the front panel at the same time. If you want to use your headphones using the back panel, short the mentioned pins and connect your headphones to the green header of your back panel audio. If you want to use the front panel, take off the jumper caps and connect the front panel cable. Remember, if you connect the front panel audio cable, you won't be able to use the back panel. If you are going to use the back panel, don't forget to return the jumper caps. Usually the 5-6 and 9-10 pins. Hope this helps.
Nov 18, 2007 | EliteGroup P4M800-M7 Motherboard
ASUS P5GC-MX/1333 Motherboard Logo
1,973 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
