Question about Allied Telesyn RG613TX Router
- port forwarding Telesyn AT-RG613TX - it's an old old router, but I can't acces the router "site" for some reason so I can open ports, help :) ?
  • 60 Answers
What is the IP address of the router? Can you still ping that IP? Try a different computer to access the router.
To ping:
Go to start >run>type cmd
Type ping IP of the router
If you get 4 replies it means it communicate properly
Posted on Jul 16, 2009
Why can't I print on cloud print with my canon inkjet mp830. It keeps saying "printer offline"
Hi, you may find that opening port 5222 in your router settings corrects this for you. This is due to Google Cloud Print (GCP) needing to poll your printer, if the port is not open then GCP will not get a response from your printer, therefore will show it as offline.
It is also possible that your firewall is blocking communications so you would need to open the same port (5222) in your firewall / antivirus software.
Warning: Ports are often closed on a router to help prevent unauthorized access to your home network. Opening any additional ports on your router may decrease the overall security of your network.
  1. To use port forwarding first determine the local IP address of the computer or device you are forwarding the port to.
  2. Open your router configuration / settings menu.
  3. Once in the router configuration locate the port forwarding settings, often in a section such as Applications & Gaming or Port forwarding. I would suggest that if you are having difficulties with this to refer to your router documentation or call their support line.
  4. You will only need to open port 5222.
  5. Give your new rule a name that you will recognise.
  6. Next enter the port number 5222, if you are asked for Externet and Internet enter 5222 in both.
  7. The protocol is TCP.
  8. Next is the IP address of the computer.
  9. Don't forget to check the enabled box if there is one and save changes.
If you have any issues with this I would suggest Port Forward web site where specific instructions should be available for your router.
Tom
Jan 10, 2014 | Canon PIXMA MP830 All-In-One InkJet...
Linksys port forwarding
This WEB site shows how to port forward.
http://www.wikihow.com/Port-Forward/Open-Ports-on-a-Linksys-Router
May 05, 2013 | D-Link DSL-G604T Wireless Router
Port forwarding
Instructions are on this WEB site.
Port forwarding
Connect your Internet phone directly to the cable modem and see if you can use Internet phone directly through the modem.
If it works through the modem then it must be the issue with the port forwarding.
First get the port numbers from the phone manufacturer.
Open the setup page of the router and open those port numbers.
Jan 15, 2012 | Linksys Wireless-G WRT54G Router
Port problem for download site
Check your router setting in Port forwarding.
open the port that your software are using.
your network setting might be set to NAT
linksys support have user manual on how to set ort forwarding.
Mar 20, 2009 | Linksys Wireless-G Broadband Router
Port forwarding
do one thing you go the inside router then select port forwarding and give the x box ip address you get it
Aug 12, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Port Forwarding with BR-6104K
hope this helps
In vegas to forward a port with the zytell modem Sprint/Embarq our DSL provider you have to bridge your modem first and allow your router to pull your IP from your ISP. Then you can forward the port.
If you have DSL I would start by going to my ISP's website and look for instructions for setting up port forwarding or Bridging your modem.
Bridging your modem passes off traffic control to your router. on zytell modems you can also forward ports but bridging is much less technical
I have not run into CABLE providers cable modems having to do this
did you allow that port in your computers firewall?
Did you set up a static ip on the computer you want to forward your port for? sounds like it is required for you router
User manual: http://www.edimax.com/images/Image/manual/Wire/BR-6104K/BR-6104K_M.pdf
instruction site
http://portforward.com/english/routers/port_forwarding/Edimax/BR-6104K/ICUII.htm
to test the port connection you can go to http://whatsmyip.org on the left pane click on port scanner and choose custom to scan the port number you are attempting to open. you do have to have the application that will use that port running to get a result if it is a game ALT+TAB should let you out of the game without shutting it down to open a web browser this tool can save you a lot of time testing the port it will give you a open status when you have succeeded.
Mar 29, 2008 | Edimax BR-6104K Router (br6104k)
Problem with post forward
I HAVE ONE OF THIS ETHERFAST CABLE/DSL ROUTER BUT I CAN INSTALL...CAN YOU HELP ME????? PLEASE
Feb 03, 2008 | Linksys EtherFast Cable/DSL Router
Port Forwarding for Allied Telesyn AR725
If you refer to this link, it should explain how to do it for you, best of luck http://alliedtelesis.custhelp.com/cgi-bin/alliedtelesis.cfg/php/enduser/std_alp.php?p_sid=psCY4LAi&p_lva=&p_li=&p_page=1&p_prod_lvl1=5&p_prod_lvl2=63&p_search_text=port&p_new_search=1&p_search_type=3&p_sort_by=dflt
May 04, 2007 | Allied Telesyn AT AR725 Router
go to this link for instructions, best of luck http://alliedtelesis.custhelp.com/cgi-bin/alliedtelesis.cfg/php/enduser/std_alp.php?p_sid=psCY4LAi&p_lva=&p_li=&p_page=1&p_prod_lvl1=5&p_prod_lvl2=63&p_search_text=port&p_new_search=1&p_search_type=3&p_sort_by=dflt
Allied Telesyn RG613TX Router Logo
429 people viewed this question
Top Allied Telesyn Computers & Internet Experts
Prashant M
Prashant M
Mirca Sekosan
Mirca Sekosan
Are you an Allied Telesyn Computer and Internet Expert? Answer questions, earn points and help others
