It doesn't work. I've change the batteries. The
It just doesn't work. I've change the batteries. The light doesn't come on. It is for AC
# on back is: 6711A20035J
If you can take the unit apart see if there are any components that are either broken off from the PCB (main board) or "cold soldered" like capacitors, wires or other passive items. If you do, just solder the piece(s) back. :)
PS. remove the battery and ground yourself and your iron as a precaution, good luck.
Posted on Jul 16, 2009
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
SUA3000RMI2U won't carry load
Did you run this test without AC input?
Also what happens when you cut off the AC mains without any load connected to it? Will the UPS continue to run or does it switch off as well?
Dec 15, 2012 | APC Smart-UPS 3000VA USB & Serial...
Computer doesn't turn on. Tried just using AC plug in with no battery but doesn't turn on. When the AC Adapter is plug in there is a orange light on when battery is in and a white light with
If you are still having trouble I would take it to a local pc technician. I have had good luck an UniComputers on 23rd st but its not cheap...
Sep 30, 2012 | HP Pavilion g4-1117dx Notebook
I've got a 96 Polaris trailboss 2x4. The headlight
How is the ground and powers to those lights ?
Sep 01, 2017 | Cars & Trucks
Ac doesn't turn on - 2006 scion xa
low coolant will not allow the compressor to come on it is a safety so you will not damage the compressor
May 30, 2012 | 2006 Scion xA
I need to reattach two deep cycle batteries to my fleetwood rv. Do I attach to one battery ms then attach the extra leads to the other battery , or do I attach the positive lead to one battery and the...
It should be positive to positive, negative to negative - parallel, not serial.
The simple way to tell is by how many cables you have. If you've got one positive and one negative, and only one jumper, it's a 24 volt system and should be connected in serial. If you've got one positive and one negative and two jumpers, it's a 12 volt system, and should be connected parallel.
If in doubt, connect up in parallel and test things. If everything works, it's a 12 volt system and you're good to go. If everything doesn't work (lights are dim, inverter doesn't give AC, etc.), it's a 24 volt system and you need to change to serial.
Serial - positive to system connection on battery 1, negative on battery 1 to positive on battery 2, negative on battery 2 to system negative.
Parallel - positive on battery 1 connects to positive on battery 2 and the system positive, negative on battery 1 connects to negative on battery 2 and the system negative.
Jul 06, 2011 | GPS
My toshiba satellite a205 will not start. the battery light flashes 6 times and stops, no other lights come on. I've tried removing the battery and power cord and holding down the power button for...
If it does the same thing w/ the battery removed and just on AC, it's a power regulator problem on the motherboard. If it works with the battery out, the battery is dead and you need a new one.
Jun 30, 2011 | Toshiba Satellite A205-S4617 Notebook
My battery doesn't recharge laptop when laptop is plugged in . What to do and at what approximate cost if new battery needed?
Hi there! There are two possible causes of the problem - it's either your battery or your AC Adapter. To diagnose whether or not it is your AC Adapter, test it this way. Does your laptop function with the power cord plugged in and the battery out? If this is the case, your AC adapter is fine and your battery is done. To replace the battery, expect somewhere between $75-$175. Here is a link to the cheapest battery site I've found so far - I use it for work all the time. http://www.batterydepot.com/mfg/TOSHIBA/LAPTOP-BATTERIES
If your laptop doesn't work with just the AC adapter plugged in, then that is your problem! AC Adapters are cheaper than the batteries. They can be purchased here for around $50: http://www.buylaptopadapter.com/toshiba-adapters.html
Make sure you match the model number on the bottom of your laptop perfectly with the model number of the battery or AC Adapter! Good luck! Alex
Apr 30, 2011 | Toshiba Satellite PSPA0U01S006 Notebook
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
