Question about Memorex MVD4544 DVD Recorder/VCR
My dvd player is humming
My player is making a really weird noise and won't always play a disk. How to solve?
    President:
  • 563 Answers
If you're in warranty, you can exchange the player through Memorex. If you're out of warranty, you'll want to buy a new player. It isn't feasible to have a player like this repaired because repair cost will be far more than what the player actually cost,
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 16, 2009
My dvd player hard drive sometimes makes a loud humming noise when the dvd stats to play?Is it an unbalance or the drive going bad? Is the drive easy to replace? Thanks.
it can be caused by a bad sled motor. Possible. no, not for the novice. unless you have experience replacing this, can damage beyond repair.
Dec 05, 2011 | RCA 20F610TD TruFlat TV/DVD
My son has a 19
the noise that you can hear is most likly to be a hum this is the power supply transformer ocillating it is quit common normally on cheaper range items but this is not always the case the noise is there when it is in use but the hum is obscured by the sound from the unit ie music of films i have dab stuff that does it really annoying at night
Jan 17, 2010 | Televison & Video
Disk won't play - says ''disk not found'' . multiple disks won't play in this player but they play in another player
Hello
After you explained the situation theres really only one conclusion. Which is that the laser inside the dvd player will be the source of the problem.
There is really only one way to try and correct this problem. Any store that sells DVD's and DVD players typically sell a lens cleaning disc. If you can get one of those you can try cleaning the lense.
If that does not solve the problem then it has become defective or malfunctioned. You could track down a local dvd repair shop but the cost of having it fixed would likely be as high as just buying a new one.
Post back if you have any further questions or comments. Thank you for choosing Fixya!
Sep 27, 2009 | Televison & Video
When i put a dvd in the player makes noise and screen says no disk or unable to read
Sounds like the mounting spindle is out of alignment, meaning the disks you load into the player are not spinning in a balanced, stable position. Without this being the case the laser pickup will not be able to read the disk and the unbalanced disk will cause a noisy hum and you may even be able to feel vibration in the player itself to confirm this. Sometimes the noise and vibration is a disks fault but if it occurs on any disk you insert (and can confirm the same disks work ok with no noise in other DVD players) it will be the players mounting mechanisim that is not playing the game properly I suspect.
Aug 18, 2009 | Polaroid DPA08055S Portable DVD Player
My Xbox 360 makes a loud humming noise while i play
The Xbox 360 does not like to be moved when playing a disk some of the mechanics may have misaligned or slightly out of sync this may be reason the DVD drive is making those sounds.
I strongly recommend you remove any visible dust from the 360 especially the sides and air vent holes using a vacuum cleaner. Once youve cleaned it place it horizontal (never on carpet) on a flat surface well ventilated away from other devices that generate a lot of heat.
As for the 'shredding sound', place in **** game into the 360 when it starts to make those sounds again gently tap the 360 on top (where the DVD drive is) until it stops making that sound. This doesnt always work but has for me and many others.
My experience tells me that dust can build up not only inside the 360 but also the drive itself which can lead disc read errors and the sounds and you mentioned.
Remember DUST and HEAT is the 360's biggest enemy and can cause RROD, 1 Red Light Problem, and disk errors.
Hope this helps..good luck!
Jul 27, 2009 | Microsoft Xbox 360 Console
Humming noise when Dvd plays
the motor that's spinning the dvd is bad. sorry you have to buy a new one if you don't want to hear the noise. hope this help
Dec 17, 2008 | Coby DVD-937 5.1 Channel DVD...
My dvd won't play any movies
the ticking sound is most likely the laser hitting the disk trying to focus, my guess is the motor isnt spinning the disc or the laser is bad or weak.
Dec 04, 2007 | Symphonic WF104
Memorex MVD4544 DVD Recorder/VCR Logo
128 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
