Question about Whirlpool WED5800S Electric Dryer
We have been having trouble with our airconditioner since moving into our home. We switched AC technicians and found a very simple problem. The dryer vent is directly behind the AC unit and is clogging up the coils. Is there an extension that I can use to move this away from the AC, or do I have to reroute the whole venting system?
    President:
  • Whirlpool Master
  • 1,922 Answers
Put an extension elbow on the pipe that exits the house and route it away from the condenser on the A/C but dont let the pipe extension get excessively long or your clothes wont dry as efficiently
Posted on Sep 26, 2009
Dryer has power wont start
Hello Dom - Being that you have narrow down some possibilities, here are a few simple troubleshooting tips that may help you get to the root cause:
1. Make sure the dryer is plugged into outlet, and plugged in correctly.
2. Is house fuse blown or circuit breaker tripped? Replace fuse or re-set circuit breaker.
3. Make sure that electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. I would recommend reaching out to a Licensed Electrician check to make sure it is on a circuit by itself.
4. Thermal limiter tripped or an internal problem with the dryer. A thermal limiter automatically turns off the motor (electric dryers only) in the unlikely event of an overheated situation.A service technician must replace the thermal limiter after correcting the fault.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Jun 19, 2013 | Frigidaire Dryers
I am looking for the reset button on my Amana heat pump the outside unit fan inside operates but the compressor does not run
There are no simple reset buttons for that...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 11, 2011 | Amana Heating & Cooling
My ac system has a model#44408 hunter thermistat and a trane heat pump. The system runs but does not change the temperature to cool the home to a comfortable temperature. is the problem in the thermistat...
You have refrigerant leak or the compressor has died...not a thermostat problem...
You will need to get a tech. to take a look at it.
heatman101
Apr 20, 2011 | Heating & Cooling
I addred coolant to the AC unit a few weeks ago and it has been running fine until last night. I went to check the pressure and make sure the line was not frozen this morning since the indoor air climbed...
It is just coincidental that the fan motor died now...
Replace the condenser fan motor and you will be good again...
heatman101
Apr 20, 2011 | Carrier 38CKC036 Air Conditioner
Hi, I have 2000 Toyota Sienna, after using the AC for some minutes its cut off and never cool again till I switch it off and on it later. I just replace the condenser and re-fill the gas. What could be...
The catalytic converter has no bearing on your air conditioning system. If the compressor is shutting off, it is because of inadequate freon, or air and moisture in the system. When you replaced the condenser, the dryer should have been replaced with a new one. The system should have been completely evacuated of any old freon and fresh freon and oil put back in the system. If the a/c guy didn't change the dryer, then the system has been contaminated with whatever was accumulated inside the old one. If your catalytic converter is bad, the computer will trigger trouble code and the check engine light will come on. Have ethe computer scanned for trouble codes.
Jan 14, 2011 | 1998 Toyota Sienna
Warning light says Low Refrigerent-AC/Off. I tried to recharge the system but the Compressor won't engage, How do I get the Compressor to come on so as I can recharge the system. Is it a pressure swithch...
in order to recharge the ac you first must clear the trouble code for the ac off warning. when you get this warning the computer shuts down the compressor to keep it from running without the lubricant that is in the freon. clear the trouble code and the compressor will run and you can recharge the ac.
Jan 05, 2011 | 1998 Cadillac DeVille
My dryer will run but will not get hot. The trouble shooting guide says that on of the two house fuses in the circuit may be blown or the thermal limiter is tripped. Where are the fuses in the dryer. I...
First id make sure you have both phase of AC power coming into dryer.
Go to your house panel and reset yoru house breaker for the dryer. If in the USA the breaker should be a 240volt / 30amp breaker. It will have two breakers tied together at the trip switch.
If AC power is good at the dryer outlet then it could be one of the followings.
  1. Open Thermal limit fuse or trip switch.
  2. Open Heater Element.
  3. Control board is faulty.
Oct 26, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Heads up I found the technician manual for my
Hi there and thanks for your comments ... I seem to spend hours here telling folks about lint, where it is and how to get rid of it. You sharing your first hand experience is appreciated.
Thanks
a
Oct 18, 2009 | Dryers
We have a Intertherm Nordyne heater/airconditioner. New, we just moved into a mfg home. The air is really loud, is there a fix for this. Someone suggested we get a different squirrel cage...
Theres all kind of answers.. close off the return grill and re route the return air system, get anouther unit, Have the realator to fix this problem or give you an adjustment, and you do it your self, ask a reputable ac man..ect, ect,,!
Sep 06, 2008 | Heating & Cooling
Whirlpool WED5800S Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
