Question about Whirlpool ED5FHEXMQ Side by Side Refrigerator
For the past two hours my refrigerator sounds like air is leaking. Could it be defrosting?
  • Whirlpool Master
  • 4,654 Answers
No not defrosting for two hours. The noise is strange to me. If it was a freon leak it would not last 2 hours. Something is happening that is out of the normal so I would try to locate the area better. Under, inside or turn off to listen if still happens..Sea Breeze
Posted on Jul 16, 2009
How do I determine the reason for excessive frost in freezer?
the seals are leaking ,letting humid air in,creating frost,get a new gasket,you will also save alot of electricity
May 20, 2015 | Whirlpool Refrigerators
Frost Shows Uo On Rear Wall Control Also Water Drips From Top Middle Section And I Have Water Build Up On Lower Pan-floor ???
Hi friend, thank you for your post!
Based off your post you are having trouble with frost on your rear wall and water dripping from the top middle section on the inside of your Frigidaire refrigerator. Sounds like you may have a possible problem with an air leak or water leak. I would suggest checking your seal to make sure there is no leak. You can do that by placing a dollar bill between the body of the freezer and door. If the bill comes out easily then the gasket may be causing frost to develop due to an air leak. I would recommend exchanging the gasket out. If the gasket is sealing properly then it could be an issue with the water line and you should perform a manual defrost that could help clear out any restrictions in your water line. To perform a manual defrost you would need to disconnect power from your refrigerator for roughly four to six hours. I hope this information is helpful. -Matt
Feb 23, 2015 | Frigidaire Refrigerators
Leaking Kenmore Refidgator
What is your model number? Sears Kenmore numbers look like this 321.2468102 I hear a lot of complaints from people that see water leaking into their refrigerator from seemingly nowhere. Water appears in different places and even inside or under a refrigerators that does not have a water or a ice dispenser! Frost free refrigerators defrost the ice that collects on the evaporator coil. Your refrigerator defrost on the average about every 8 hours so the water that accumulates during defrost has to go somewhere right? Yes the water is supposed to drain down a small drain line to a pan down near the compressor where warm air from the condenser fan will blow warm air over the water and evaporate the water again an put it back into the air inside your home, office or wherever your refrigerator is located. Over time that little drain tube gets slime, algae and a gooey white paste gunk that fills the drain line sides up stopping the waterflow downward to the condensate pan below refrigerator. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers. Gunk is an accumulation of algae slime and just crud that appears from nowhere in a refrigerators defrost condensate drain line. How a refrigerator leaks is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Here is an example of a ET18PKXGTO Whirlpool refrigerator leaking water into a cup below the freezer compartment. Click here=> Whirlpool Leak Photo taken by TechnicianBrian. TechnicianBrian.com. And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Jun 19, 2013 | Refrigerators
Water is leaking from inside of the refrigerator and we are constantly wiping off water from the floor. The icemaker isn't working.
I don't mean to sound sarcastic here but have you lifted the icemaker arm to see if the leaks stops? If it does the icemaker water inlet thru tube from the back of the unit is somehow wither not alightned with the icemaker inlet or the icemaker itself is letting water go though it.
Having said that if your unit is all froze up in the back of your freeze and the fan can no longer circulate air properly that too can cause bot the icemaker to stop working and a leak if the upper cabinet drain is iced over.
You can make sure it is not an icing / "not defrosting" problem by unplugging the unit and placing a fan blowing into the freezer section for at least 2 hours. Mind you this will only add to your water messes but it is a must do so have the mop and rags ready when you do this. Once you have done the fan routine plug it back in and see if after 8 or more hours that the leaks stop and the icemaker functions.
If after all of this it does funtion normally then you unit is not defrosting and will need to have the defrosting system checked out. NOTE after a few days (3 - 6) it most likely will start freezing up again if there is in fact a defrost problem and it will repeat the same antics in the past. Hope this was helpful.
Jan 18, 2010 | Refrigerators
Freezer all of a sudden started major frost build up owned for approx 6 months mostly on left side seals all look tight french door style
I was going to suggest you have a leak - outside warm air / moisture coming in your freezer but you mentioned the seals are tight.
The next most common problem is your defrost system - refrigerators use 2 methods to control forst - timer defrost or adaptive - adaptive is used on newer ones and will defrost as needed - the timer version is based on your compressor run time - about every 6 to 12 hours or more or as needed, your compressor motor will turn off and you should see what looks like a red/orange heating element through the vents in your freezer and hot air coming out - on some freezers it is hidden and you won't see it, but you will notice hot air - you will hear sizzling sounds, and water dripping - that is your defrost kicking in - there should NOT be frost build up at all iny our freezer - if it is the case, then your defrost timer is faulty or the control board needs to be changed, all this is at the back of your freezer panel, you have the board, heating elements, defrost timer and limiter - all these components need to be checked when you have your unit serviced. Overfrost of the evap will cause your refrigerator and freezer not to cool properly as well.
Sep 01, 2009 | Samsung Refrigerators
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Kenmore refrigerator is warm, freezer is melted down
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
Mar 29, 2009 | Kenmore Refrigerators
PLHS267ZA
The guide that funnels the water into the ice maker needs to be replaced. The cause of your problem is that water is leaking into the back, freezing there, and blocking the air flow. Mine sounded like an idling semi truck with engine problems.
Jan 06, 2009 | Frigidaire PLHS267ZA Side by Side...
FREEZER SOUNDS VERY NOISY
I turn off the power of refrigerator for 24 hours and defrost the frezzer. The noisy sound stopped. I think sometimes we did not close refrigerator tightly, the ice built up caused the problem.
Jan 04, 2009 | Jenn-Air JCD2389G Side by Side...
2 year old kenmore elite water leaking in freezer area
Does this happen when unit is in a defrost?? If so, sounds like the drain line is clogged.The hose and pan are located under the unit.You can access this by removing the cardboard back cover.Find the drain line tube.I'm sure the drain opening at the evaporater is iced over.You will have to unplug the unit and keep the doors open to defrost.(Removing product in unit will decrease defrost time.) Maybe an hour to an hour and a half.Could be longer!! Try using a wet/dry vac to clear.
Nov 25, 2007 | Kenmore 53642 / 53644 Side by Side...
Whirlpool ED5FHEXMQ Side by Side Refrigerator Logo
115 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
