Question about Zebra P330i Thermal Card Printer
Zebra P330i Printer not counting the YMCKO ribbon correctly
I am using the recommended 5-panel color ribbon for my Zebra P330i printer, which is supposed to print 200 cards. However, when it gets to 150, it stops and tells me I'm out of ribbon. It has done this with several ribbons - is there some way to reset the counter so it will print the full 200? These ribbons aren't exactly inexpensive.
    Champion:
  • Zebra Expert
  • 285 Answers
!RIBLEN - - - - Get number of remaining panels on ribbon
Send the command !CSA_0
Send the command !CSA_1
Posted on Nov 27, 2010
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
Unfortunately it's not a number stored in the printer, it is actually stored on the ribbon. If it is not counting correctly then you may want to try updating the printer firmware to the latest version.
Posted on Oct 19, 2012
Can i use Zebra i-series YMCKO ribbon in Javelin i-series printer
hi, not sure, but they have diferent ribbons, 800000-440 or -415 ....
try difirent ones
May 13, 2014 | Zebra P330i Thermal Card Printer
P330i gives out of ribbon error. When completing command "!SA" it ran the blank card through the printer into the other side. After right after that the printer flashed the "out of...
The printer uses three sensors in relation to the ribbon. The RFID (chip on ribbon). When you go into the printing preferences for the printer it should detect any color ribbon, and say ribbon type changed to (ribbon type). If so both the ribbon and RFID sensor are working properly. Then there is the color ribbon sensor, which has the blue and amber LED's, and is used to detect the panel of the ribbon. Thirdly the flag sensor which is on the back end of the supply reel, to detect the ribbon turning. . Additionally, CALIB command has never worked for me. !SA is an auto self adjustment for multiple sensors. additional you can use !CSA 0 without ribbon in machine, then run !CSA 1 with a ribbon (color ribbon is a must with any calibrations). You can also run !SAP 0 for card sensors !SAP3 for mag encoder card sensor. !SAP 1 for ribbon calibrations. if all else fails, you can manually set the ribbon by using !CSA 5 70 120. Please remember these commands are for genuine zebra I Series printers, and that they are case sensitive, and spaces are present. If none of the above corrects the issue you may need to replace one of the three sensors, the daughter board, or possibly the main logic board.
Sep 20, 2011 | Zebra P330i Thermal Card Printer
My zebra card printer p330 i donbt recognized the colour ribbo YCMK, only detect the mono ribbon
The P330i is not supposed to work with the YMCK color ribbon, you should use the YMCKO 800015-440 color ribbon.
-- The Pros at www.DiscountIDStore.com
Sep 25, 2010 | Zebra P330i Thermal Card Printer
Keep getting Out of Ribbon message even i changed ribbon..printer zebra p330i card printer. how can i fix it?
I assume you are using YMCKO ribbon rather that K monochrome. If using YMCKO (or a few other specialist ribbons) the spool has a large blue collar at the back with a paper covered chip. The chip has to be for the P330i rather that the Javelin or Polaroid version of the printer. The code on the YMCKO ribbon should be 800015-440. There are a number of companies selling cheap knocked off ribbons that claim to be compatible. That could be part of the problem. The printer has to communicate back to the windows driver when a ribbon is changed, maybe there is a comms problem, try another USB port or reload the driver.
Sep 18, 2010 | Office Equipment & Supplies
This is an old post but i still need help!! What does a Polaroid p85igc card printer use for a full color ribbon? Zebra p330i ymcko ribbon won't work
Right, zebra/eltron made the P310 printer before they started using smart ribbon. They also made the same printer as the J310 for Javelin and the P75 for Polaroid. These all ran on the same ribbon. Then there were the first "i" series machines the Zebra P310i, the Javelin J310i and the Polaroid P75i. These all ran on their own respective i series ymcko ribbons. Now here is my theory.... The new Zebra P330i runs on the same ymcko ribbons as the P310i and the Javelin J330i runs on the same ribbon sas the J310i. Don't know where the model number came from but the Polaroid P85igc is the same as the 330i printers. It therefore stands to reason that it will run on the same ribbons as the older P75i printer.
The YMCKO ribbons for the Zebra are coded 800015-440 for 200 print rolls, 800015-540 for 350 print rolls. I have seen a picture of a ribbon with 800015-540POL on it advertised for the Polaroid but cannot find anyone to sell it. I can find however a few US references to a ribbon for the P75i One is linked below. It may be worth a go if you get desperate. //www.identisource.net/pd_3151.cfm
The other alternative, as the machines are essentially the same, is to change the motherboard so the printer thinks it is a Zebra or Javelin and then buy much more readily available ribbons. We can swap the board for you but as a spare they are just over £400 incl VAT. YMCKO ribbons would only be around £30 for 200 image rolls, thats the genuine stuff not the knocked of rubbish that's around. www.pci-solutions.co.uk I shall investigate to make sure we can't "rebrand" the printer by changing its firmware, but I doubt if it will be that easy.
Aug 29, 2010 | Office Equipment & Supplies
What does a Polaroid p85igc card printer use for a full color ribbon? Zebra p330i ymcko ribbon won't work.
The "i"suffix was introduced in around 2005 to try to stop patent infringements on the printer ribbons. They introduced a chip on the spool that feeds back to the printer. The chip has to be the correct coding for the badge of the printer. Zebra P330i printers are essentially the same as Javelin J330i and Polaroid p85igc but have three different part numbers for their YMCKO ribbon. You can run any monochrome ribbon on them because the mono ribbons have no chip.....not much profit for the brand owners. YMCKO however is not interchangeable. Find a Polaroid dealer for the full colour ribbon.
Jul 08, 2009 | Zebra Eltron P310 Thermal Printer
P330i ribbon breaks on solid blue background
Pls sent ribbon 200 YMCKO i serie prices to me in this volume 10,50 and 100 rolls .
Thank you
Tanny
tor_rtt@yahoo.com
Apr 23, 2009 | Zebra Eltron P330i Card Printer
Zebra print jus blue color
The "i" is the newer series. You will run into problem trying to install the P310C with the P310i drivers. More so if you are running Windows Vista. In that case don't even try.
If your computer has excepted the drivers that you have. Go into the Printer Properties; General Tab; Printer prefs; Advanced button in the bottom right corner ;next, and change the Ribbon type. K is for Black 1 color ribbon.
Try YMCKO for Full COlor. If the ribbon is also YMCKO.
Yellow, Magenta, Cyan, Black, Over lay...
Jan 31, 2009 | Zebra P310I Printer
Zebra P330i Thermal Card Printer Logo
1,882 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
