Question about Whirlpool RF111PXS Electric Range
Lower element in oven stopped working. Can I replace this on my own? Oven is less than a year old.
This is generally a simple procedure. May I suggest www.repairclinic.com.
They are an excellent resource for parts and basic instruction.
Posted on Jul 16, 2009
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Replace or fix a 10 year old JTP56 GE Profile double oven
The heating element is easy to replace and you can buy it online...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 20, 2010 | GE Profile JTP56 Electric Double Oven
We have a whirlpool oven with a lower and upper oven which is also the grill. It is about 3 years old and the bottom oven has stopped heating up. The light still works and the fam but has no heat. What is...
If the fan is working o/k, then it is more than likely that the oven element has failed.
This is to be found at the rear of the inner oven compartment behind a removeable cover.
Mar 30, 2010 | Philips Ovens
MER687BAS WONT HEAT BOTTOM OVEN ONLY BROILS IS IT JUST THE ELEMENT?
Steps to check element. TURN off breaker that feeds oven. Unistall bottom element in question. With a continuity tester see if element has continuity. If it does not then element is bad, replace it and turn on breaker. If it does you need to call a technician because the next step requires voltage testings that can shock you if done improperly..
Nov 13, 2009 | Maytag MER6872BAS Gemini Electric Kitchen...
Lower oven does not heat up the fan and light still work it is just under three years old what could be the problem the upper oven works fine. it is a whirlpool oven
If `the fan is working o/k, then you need to replace the oven element, located at rear of oven
Please rate my solution.
Thanks.
Aug 19, 2009 | Ovens
The lower element stopped working! Can I replace
Hello. You can certainly DIY, and here's how: Trip the breaker for the stove at the main panel, and be sure that all power is off at your stove/oven. Depending on your particular model, you will either disconnect the element from the wiring at the rear if the oven, or it will unplug from the inside, usually after loosening two screws adjacent to the element. Either way, remove the element. If you have an electrical meter and know how it's used, you can test the element for continuity. An open circuit would indicate that it is defective. If you do not have a meter, you can just take the element with you to an appliance parts supply business, and they'll test it for you. I always take my old part with me, so I can make sure that the part I purchase has the same terminals as the one removed. Installation is the reverse of the removal.
Hope this helps you!
Regards, --W/D--
Jul 16, 2009 | Whirlpool Kitchen Ranges
Delonghi AS690 toaster oven lower element won't turn on.
Cactus Bob Is WRONG. I've had these replaced; and then, when it happened subsequently, bought the part and replaced it myself. You have to take the entire thing apart. but it can be done.
Mar 13, 2009 | DeLonghi AS690 Airstream Stainless Steel...
Fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Jun 30, 2008 | Frigidaire 30 in. Electric Gallery Series...
Whirlpool RF111PXS Electric Range Logo
85 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
