Question about GE 30" Self-Cleaning Freestanding Electric Range - White-on-White
My 10 year old GE self-cleaning oven/range (Model J DP37G0T188) has got stuck in self-cleaning mode with an F3 error. We shut it down using the electric breaker. Door latch is locked. Is the temp sensor burnt? How do we open the door and fix the problem?
  • rvalue1 Jul 17, 2009
    Since posting the note, I had shut down my electric circuit breaker to cool the oven down. Next morning I turned the circuit breaker on to feed power to the Oven. Oven door opened and the oven works fine. I am all set. No assistance required at this time.
fridgetech
  • 473 Answers
SOURCE: Error code F3 on Kenmore 911.4658815 electric range
The oven temp. sensor has gone bad.  Replace it and that will solve your problem.  The part # is WB21X5301 and cost is $73.49.  Can purchase at http://www3.sears.com/.  You can view the image at http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0124160&brandID=0582&modelDesc=Free%20Standing%2C%20Electric&modelNumber=9114658815&documentID=00053545&documentTypeID=PLDM&documentClassCode=PM&titleType=BODY%20SECTION&titleID=00002&.  It is inside the oven in the upper right or left hand corner.  Should be able to remove from the inside.  Two phillips screws and pull it out harness also.  Plug new one into harness and put screws back in and you are done.
Posted on Oct 17, 2007
  • 1314 Answers
SOURCE: Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Posted on Feb 12, 2008
  • 1314 Answers
SOURCE: GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Posted on Feb 14, 2008
SOURCE: Can't Get My GE Profile XL44 Self-Cleaning Gas Range to CLEAN ! ! ! ! !
I also have a XL44 (GE JGBP90) and I can't figure out how to latch the door. When I press Self Clean, the display asks me to latch the door, but I don't see a lever. I think it might involve lifting the range, but I don't want to force it. Any ideas?
Posted on Mar 10, 2008
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Posted on Dec 28, 2008
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Stuck in clean mode. Ge Spectra xl44 My wife cleaned the over a couple of years ago using the self cleaning mode and ever since then the oven has been stuck in clean mode when we try to use it. I've...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 25, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Shutting off
Hi, you need to have your control board rebuilt or replaced (if it's stll available). Here's an article I wrote on this failure last year if you want to read the details. http://appliancejunk.com/blog/2009/10/24/oven-failure-after-self-clean-and-f1-errors/
Aug 01, 2010 | GE JKS05 Electric Single Oven
The oven won't lock shut for cleaning
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Code e2 f3 appears, oven goes to self clean mode,
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(*&^%
Oct 12, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
Control screen flashes F2 and F3; now oven element won't heat.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Feb 10, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Our Oven seems to be stuck in the Self-cleaning mode
Have you tried unplugging it and then reapplying power after a few minutes? Sometimes a power down/up cycle will reset the logic..
Sep 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
458 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
