Question about Nokia 6233 Cellular Phone
Power up shows spinning envelope/"c" symbol,goes to white screen cycles round twice like this then powers off
1)when cycle reaches final spin cycle (about 10 minutes remaining) it will attempt to spin for a few seconds and then stops. It displays no Code Symbol, it shows the remaining 10 minutes. 2)Remove all...
Sorry but this is always where I start with funny problems like this and so many times it has cured problems ;-0)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 21, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My phone does not have any problems, I was just wondering if you could tell me how to remove the envelope from the screen, Thank you
This means you have a text message, look for something that says "messages" and go in and read them all. After you read them or delete them the envelope will go away, if you have problems ask someone to help you find your text messages in your phone.
Sep 02, 2010 | Lands Phones
Panasonic KX-TG1855AL envelope and speech bubble symbol
Hi, you probably won't get this anymore, but here is the fix (I had the same problem and couldn't get rid of it. Had no messages or calls that I hadn't viewed). You will laugh but press the Clear / Mute button for a few seconds. That is the bottom right button out of the four that are around the big round one. It has a C on it, a line under the C and the mute symbol underneath... Good Luck. Julia
Jan 08, 2010 | Panasonic Lands Phones
I got a can not play media while phone is active message. Than I turned off and on the phone after that didnt solve my problem, I pulled out the battery. When I put in back in and tried to turn on the...
Remove the memory card and the battery from the phone.
Press and hold down the power button for 15sec.
Now put the battery back in and check.
If it works, you can out the memory card back in.
Jul 14, 2017 | RIM BlackBerry Storm 9530 Smartphone
Washing mashine dispalys symbol not in users manual.Where time is displayed it shows a symbol that look like a padlock.The machine does have a key symbol on side panel. Door is showing unlocked. Cannot...
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
Mar 30, 2009 | Electrolux EW1000i Front Load Washer
Cant receive txt there is a envelope icon with a stop sign by it
Most of the time that symbol means that your inbox is full. If your inbox is not full try taking the battery out for 3 min so your phone will do a hard reset
Mar 21, 2009 | Motorola Mobility C168 Cellular Phone
Sony Bravia 40 inches has a defect
More then likely your power supply failed. If you do not hear a click from the relay during the power up cycle then your power supply failed.
Jul 29, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Nokia 6233 Cellular Phone Logo
87 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
