Question about Delphi TNR800 Car DVD Player
How do you do the wheel speed calibration? In the Nav setup options where you can reposition your vehicle it gives an option for wheel speed calibration but it say select after wheel speed calibration. How do you do the wheel speed calibration? My vehicle is a 2005 Yukon and the problem I have is that after about 15 miles of driving my vehicle is farther on the map than it shows. Its like the farther I drive the farther ahead I get. Is there a way to fix this? Thanks Bret
I don't know if this can help but try the following:
1- press the RPT/NAV Button untill you hear the beep.
2- hold the config button for arround 30 or 40s until you heard the beep, now a new config screen is opened.
3- try the 3rd button on the right as i remember, you will open a new screen where you can adjust the distance and the number of pulse(related to the Vehicle Speed Sensor).
4- don't try to mess with anything else like Memery clear or program Clear or anything else or i beleive you will lose the programming.
Posted on Jul 26, 2009
02 expedition 4x4 has code 1270 and speedometer is way off won't shift in all gears
P1270 - Engine RPM/Vehicle Speed Limiter Indicates the vehicle has been operated in a manner which caused the engine or vehicle to exceed a calibration limit. The engine rpm and vehicle speed are continuously monitored by the PCM. The DTC is set when the rpm or speed fall out of calibrated range. For additional information on the engine rpm/vehicle speed limiter, refer to Section 1, Electronic Engine Control (EC) System , Powertrain Control Software.
  • Wheel slippage (water, ice, mud and snow)
  • Excessive engine rpm in Neutral
  • Vehicle drive at a high rate of speed
The DTC indicates the vehicle has been operated in a manner which caused the engine or vehicle speed to exceed a calibrated limit.
Jan 26, 2017 | Cars & Trucks
2006 gmc envoy Denali 4wd will not engage
This vehicle had option of three different transfer case ! Which one of these is the one in your vehicle ?
Transfer Case - NVG 120-NR9 Transfer Case - NVG 126-NP4 Transfer Case - NVG 226-NP8
The New Venture Gear model NVG 226 RPO NP8 transfer case is a two speed automatic, active, transfer case. The NVG 226 provides five modes, Auto 4WD, 4 HI, 4 LO, 2 HI and Neutral. The Auto 4WD position allows the capability of an active transfer case, which provides the benefits of on-demand torque biasing wet clutch and easy vehicle tuning through software calibrations. The software calibrations allow more features such as flexible adapt ready position and clutch preload torque levels. The technology allows for vehicle speed dependent clutch torque levels to enhance the performance of the system. For example, the system is calibrated to provide 0-5 lb ft of clutch torque during low speed, low engine torque operation, and predetermined higher torque for 32 km/h (20 mph) and greater. This prevents crow-hop and binding at low speeds and provides higher torque biases at higher vehicle speeds, to enhance stability.
The New Venture Gear model NVG 126 RPO NP4 transfer case is a one speed automatic, active, transfer case. The NVG 126 provides only one mode, Auto 4WD, and is transparent to the operator. The active transfer case provides the benefits of on-demand torque biasing, wet clutch and easy vehicle tuning through software calibrations. The software calibrations allow more features, such as flexible adapt ready position and clutch pre-load torque levels. The technology allows for vehicle speed dependent clutch torque levels to enhance the performance of the system. For example, the system is calibrated to provide 0-7 N?·m (0-62 lb in) of clutch torque during low speed, low engine torque operation, and predetermined higher torque for 32 km/h (20 mph) and greater. This prevents crow-hop and binding at low speeds, and provides higher torque biases at higher vehicle speeds, to enhance stability
The New Venture Gear (NVG) model NV120, RPO NR9 transfer case is a single speed, full-time, all wheel drive (AWD), transfer case that incorporates a front/rear drive differential carrier assembly.
Nov 19, 2016 | 2006 GMC Envoy Denali
My 2003 lincoln LS v8 is showing codes p1714 p1715 and p1270. What are those and how do I fix it?
P1270 - Engine RPM/Vehicle Speed Limiter Indicates the vehicle has been operated in a manner, which caused the engine or vehicle to exceed a calibration limit. The engine rpm and vehicle speed are continuously monitored and evaluated by the PCM. The DTC is set when the rpm or vehicle speed falls out of a calibrated range. For additional information on the engine rpm/vehicle speed limiter, refer to Section 1, Electronic Engine Control (EC) System , Powertrain Control Software.
  • Excessive engine rpm in Neutral or operated in the wrong transmission gear
  • Vehicle driven at a high rate of speed
The DTC indicates the vehicle has been operated in a manner, which caused the engine or vehicle speed to exceed a calibrated limit
Sep 11, 2015 | Lincoln Cars & Trucks
Have a 2002 buick rendevouz. at first it wouldnt start. I mean no power at all. So we thought it might be the alternator. Husband moved wires close to the battery and it would.come on but it was like a...
Before replacing parts you don't need BCM which would need to be programmed ,dealer . Your still going to need to take it to the dealer for the radio .
Radio Setup
Important: The Radio Setup option does not contain a submenu. Radio Setup will configure the following systems:
• Steering wheel controls
• Learn VIN
• DTCs
• Class 2 radio messages
The radio setup procedure will also clear the following messages:
• CAL
• CAL ERROR
• CALIBRATE
To setup a new radio for the vehicle, perform a VIN Relearn, located in the Special Functions section on the scan tool. Cycle the ignition when complete.
If the radio is not properly setup, the radio will display a locked message (LOC) or Calibrate.
Jul 25, 2017 | 2002 Buick Rendezvous
Ok well i bought the wheel and i have this game called dirtfactor and i was trying to drive a latemodel and it doesnt turn at all it turns a little but barly......also when i do sprint cars it turns but...
I wouldn't say it's a lack of the wheel being cheap I'd be more inclined to say it's "because" the wheel is cheap. Seriously, Have you tried to calibrate the wheel using the windows calibration routine found in your control panel under Game Controllers.
Obviously the wheel is operating but barly sorry, barely. That means it is working and giving input to your computer so if that input isn't enough you either need to calibrate in windows or maybe there's even a calibration routine in the game you're playing, maybe under options. Calibration by the way is found under properties on the Game Controller section. Try it.
The test section of the windows section will tell you just how far your wheel is turning or directing your cars by means of a box with a cross in it. The more you turn the wheel the further that cross will move. Test it first, then do the calibration and then test it again. I'm sure you'll see a big difference.
Apr 21, 2010 | Genius Twin Wheel F1
No speed sensor detected
sPEED SENSOR WIRE ON SAT NAV UNIT IS brown,bUT THE SENSOR WIRE IN YOUR VEHICLE COULD BE ANY COLOUR AS MANUFACTUREERS USE DIFFERENT COLOURS
Apr 08, 2010 | Blaupunkt DX-V GPS Receiver
Nav-cam 7700 returning to main menu after planning route
i have the same problem, turn the speed cameras off im afraid
May 15, 2008 | Evesham Nav-Cam 7700 GPS Receiver
JVC KD NX 5000 NAV UNIT NOT CALIBRATING TO MY LOCATION
If youve rigged it to watch dvd's while moving. the sat nav thinks the parking brake is on and wont move. The vss cable needs to be connected as well.
Mar 16, 2008 | JVC KD-NX5000 Car Video Player
Delphi TNR800 Car DVD Player Logo
216 people viewed this question
Top Delphi Car Audio & Video Experts
Lawrence Oravetz
Sam Bedggood
Andrew Taylor
Andrew Taylor
Are you a Delphi Car Audio and Video Expert? Answer questions, earn points and help others
