Question about JVC AV-56P575 56" Rear Projection HDTV-Ready Television
The felt strip behind the screen is falling down in the top left how do i fix it?
Mine did the same. Just take out screws around the back cover at top. Reach in and remove it.
Posted on Jul 29, 2009
Screen repair manual
Basically you start by removing the rubber bumpers located at the 4 corners and along side the plastic strip that goes around the lcd screen. One they are removed you can remove the screws that hold the plastic strip. Use your finger to pry the plastic strip off.
Next you start removing the screws that hold the lcd screen on the sides. Then tilt the lid forward and the screen will fall into your hand. Don't let it fall down on the keyboard because there is a cable in the back of the lcd screen that you will need to remove. The cable might have a piece of tape at the connections to make it secure.
If the screen does not fall down then you might have screws at the 4 corners that are holding it, so remove them.
Below is a link to a video on how to do it.
http://www.youtube.com/watch?v=Nyn1hZHeSXQ
May 15, 2012 | Computers & Internet
What is the felt strip called that is across the top of my laptop where the power button is. The strip is missing and I would like to replace it. Compaq 6720s. It is above where the keyboard is and is...
HP doesn't list it in their Service Manual. No part number given.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=3442832#3
This link should take you directly to the heading - Service and maintenance information
Click on the first file listed,
HP Compaq 6720s Notebook PC - Maintenance and Service Guide
This is a PDF file. It may take up to 30 seconds before you see the first page come up.
It may also take additional time for the file to fully download.
(The computer you are using has Adobe Reader on it, which uses PDF files)
In the Bookmarks menu to the left, click on the + sign to the left of - Illustrated parts catalog.
Now click on - Computer major components
(You may wish to make the view size smaller. Click on the Zoom Out icon { - } at the top)
This is page 14 in the PDF file page number box. (At the top of the PDF file)
Scroll through to Page 30.
No listing for a separate felt strip.
Haven't worked on one yet. I would be willing to guess that the felt strip is part of the Keyboard, (Page 50)
I don't think it's part of the Switch Cover. (Page 48)
IMHO I would buy a piece of felt with the dimensions and thickness you need, and install it myself.
You now have the Service Manual.
(I suspect some form of rubber cement is used to tack the felt into place)
BEFORE you begin!
Observe Anti-Static Precautions.
Read Page 33 to 35 first.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 25, 2011 | HP Compaq 6720s Notebook
Model #: GE DRSR495EGWOWW metal on metal scraping sound bottom of drum top of lower lip, near blower motor. Cannot seem to identify exactly what is causing this. Things I have done: replace the glide...
check the felt strip,i've found screws,pennies,nuts and bolts stuck into the felt strip or the blower wheel is scraping,usually it's the rear gearing,the sleeve wears down part number WE1M462 and it's like 12 dollars
Apr 24, 2011 | GE Dryers
How do i remove the cover to change the light bulb inside?
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Nov 20, 2010 | Neff H7871 Convection/Microwave Oven
Blinking toshiba satellite A 05-54547 problem
A blinking monitor just might be a loose connection of the main display cable that runs up the left side of the display and connects to the motherboard. Also check the two wire cable attaching the inverter to the screen. The bezel of the screen will have to be removed as well as the power strip and keyboard to check the display cable. Remove the lcd screen from its hinges and look behind the display, there is a flat cable that plugs into the top edge of the screen. This cable has a habit of getting loose and falling out of the socket.
Now there is a chance that the BIOS of the laptop needs to be updated. There are many instances where the display starts acting up and a BIOS update is the correct action to take. Go to the Toshiba support site, put in the model number and then put in your operating system. Scroll down to where the BIOS is listed under downloads/drivers. Download and install the new BIOS, reboot.
Nov 08, 2009 | Computers & Internet
Strips of 2 inch wide black and white, running top to bottom
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Jun 16, 2009 | Philips 200P4 (Silver/White) 20.1 in. Flat...
Message says that the ink overflow is full. How do I replace or correct the problem on my Cannon iP 1500?
1) Underneath the print head are 2 foam pads. Turn your printer on with the cover open and then unplug it with the print head away from the pads.
2) The 2 pads have 2 silicone tubes attached to them that run to the rear right side of the printer.
Taking the sides off you can unsnap plastic clips to remove the top half of the printer cover.
3) Follow the silicone tubes. They run into a white plastic pump that sucks the ink that falls onto the pickup screens and dumps it onto numerous felt absorber strips under the pump mechanism.
4) To clean or change the absorber felts you must first remove the Pump mechanism which is held on by 2 screws so that you have access to the felt absorber pieces
5) Run clean water over each piece of felt until the water runs clear and then place them on an absorbant surface (paper towels maybe) to dry.
6) Put it all back together the same way you took it apart.
This can be extremely messy, be careful not to get the ink on anything that matters.
Jun 03, 2009 | Office Equipment & Supplies
Whilpool Side-by-Side ED5PHEXNQ00 Ice Maker Stopped Working. The "level" is down indicating that is needs more ice to fill the bucket, but the ice maker will not make more ice. I felt in the tray, but I...
There are 2 clips that hold the Ice plus on. 1 top left, and 1 on the right side.
Slightly pull up on the front of each clip and remove the controller. most likely behind this you will find a gear that is broken and may fall out of the unit. As usual you can not buy just the gear. Contact Whirlpool for the replacement gear assembly.
Feb 11, 2009 | Whirlpool ED5FHEXMQ Side by Side...
GE Commerical Dryer
First, UNPLUG the unit from the wall please. Next, open the door, and on the inside top of the door area in the cabinet, you will see either 2 or 4 screws holding down the top of the dryer. Remove these screws, then lift the top off. Now, looking down inside the cabinet, you will see as screw on either side, towards the top that holds the front onto the cabinet. Remove these two screws, then fold the front down towards you, and lift slightly to remove the front from the slats at the bottom. Use caution, because more than likely you will still have wires attached going to the thermostats, door switch, etc. Also be sure when replacing the felt, you use a lot of caution around metal edges. These things are razor sharp, and will put a deep cut on you in less than a second. Let me know if you need further help or information. Thanks and Good Luck!!!!
Feb 14, 2008 | GE DCCD330EDWC Dryer
Protron 32c lt32c1p1 screen
Can you post a picture of this?
Assuming it hasn't affected the operation (yet), you may want to have it corrected because the many cable connections to the display matrix depend on tiny contacts that use pressure to hold them in place. The foam you are talking about is used to support this pressure.
Dec 29, 2007 | Protron PLTV-32 Television
JVC AV-56P575 56" Rear Projection HDTV-Ready Television Logo
108 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
