Shutdown problem Hi Experts, I recently installed new ide 160 GB hard disk to my desktop m/c & installed xp os. while installing xp os i came across an BSOD saying turn off the ACPI option & i did it, it worked. After that i installed drivers. Finally when i planned to shutdown the m/c i found that my standby button is not highlighted. I clicked on the shutdown button and it showed m/c is shutting down, after that display went off but i discovered that my cpu is still running. Every time i have to turn off manually. This is really an headache. I updated bios, installed sp3 but still no luck. Motherboard - A7V266-MX(asus). Please someone help me out. Thanks in advance.
  • 1,183 Answers
Follow the steps listed on the link below
http://support.microsoft.com/kb/810903
For me it was step 5 that resolved the problem on my old xp machine.
Thanks for using Fixya
Proton
Posted on Jul 16, 2009
HARD DRIVE NOT EXIST ERROR!!!
If you installed Linux successfully on your hard disk then the hard disk is OK.
If you are installing Windows Xp and it does not detect the hard disk but the BIOS detects the hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
May 01, 2012 | HP Computers & Internet
Can not install os, computer says no hard disk installed
This laptop has a SATA hard drive.
Feb 23, 2012 | Panasonic Toughbook CF-30 Notebook
I cant download op cd
If the new hard disk is a SATA hard disl then the problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Feb 18, 2012 | Computers & Internet
Is it possible to use ID harddisk and SATA harddisk at the same time?
You can indeed mix IDE & SATA drives on a computer. If installing the OS (Operating System) to the IDE HD, you will only need to instruct the BIOS to boot the IDE HD drive first.
If you decide to install an OS on & boot the SATA drive first; you will need to instruct the BIOS to boot the SATA drive first and may need to provide a driver for the SATA controller - if the OS install does not recognize the SATA drive. The driver should have been included on a disk or diskette with the controller (or on the motherboard driver disk if a built-in type controller). You should see a prompt asking "If you need to install a driver.... press F6" (or similar). Press the F6 key and supply the driver disk - and follow the prompts.
Nov 24, 2011 | ASUS K8V-MX Motherboard
My Toshiba mk4058gsx HDD is not detecting
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 20, 2011 | Toshiba (MK4058GSX) 400 GB SATA Hard Drive
I have HP Comaq Presario SR1617CL Desktop PC, part number ED870AA with a Samsung SpinPoint P80 SP1604N - hard drive - 160 GB - ATA-133, I would like to upgrade to a 500GB hard drive. I have a ASUS A8AE-LE...
XP cannot be installed natively on an SATA disk without the appropriate driver which must be loaded during the install - an extremely complicated maneuver. The best way to deal with that is to just add the new SATA hard disk: install XP on the PATA and use the new SATA for your files as a separate partition. The adapter cable can be bought for about $5 from the same shop as the hdd.
All the other modifications are just fine - just remember , the RAM will not be fully recognized and used because of the limitations of the 32bit XP.
Mar 11, 2011 | HP Compaq Presario SR1617CL PC Desktop
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
I am installing a new WD3200AAJB HD in a Dell Dimension 4550. This is the only HD in the system. There are also 2 CD drives and a floppy drive. I used the jumper settings the drive came with which pins...
Reinstall your old hard drive as master and install the new hard drive as slave.
Here is the link to jumper settings from Westrn Digital;
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1540&p_created=#jumper
If you've got your jumper settings wrong and installed your os on the 127 GB section of the 320 GB Hard drive and you change jumper settings and then you have problems you may need to reinstall the old hard drive as master and the new hard drive as slave. Reformat the new hard drive as 320 GB, and as a bootable drive. You can either do a disk copy from old to new or reinstall your os on the 320 GB drive. Please let me know how this goes. You can get to me @ johnkariotisjr91741@yahoo.com
Oct 25, 2009 | Dell Dimension 4550 PC Desktop
Pci ide controller for third hard disk i have connected a third hard disk160 gb in my desktop via pci ide controller card in windows xp. hard disk is not being...
first u shud check if the BIOS is detecting ur new HDD.
if its not u can activate the new port through bios in the advanced peripherals options sectin :)
Jan 30, 2009 | Sabrent SBT-RDIT PCI IDE Silicon Image...
New hard drive 160 GB ATA can't be partitioned
why dont you try 40000 in the first partitioned..if doesn't work.. try fix your hard drive using a seatools, a bootable disk, that can detect and repair a bad sector for a hard drive..
Feb 26, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
