Felix, Brad Brown absolutely correct about mixing water with trucks engine electronics. You can possibly give it a helping hand by removing distributor cap and ensuring it gets dried inside and use a hair dryer on the rotor, wires, etc. to aide in drying what you can.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Engine got wet and will not start Ford F150 Forum Community of Ford Truck...
Wet Engine now Won Start Ford Truck Enthusiasts Forums
engine got wet now wont start
http://www.automotiveforums.com/t542259-washed_engine_and_now_won_t_start.html
SOURCE: 2000 Ford Expedition wont start
On the engine there is a tube that supplies fuel to the fuel injectors, on that tube there is a valve, like a metal tire valve, this is the fuel pressure test port, you will need a special guage to check the pressure that screws onto that valve, Kragen and other parts stores sell this test kit, it is very inexpensive, about $20.00, but cheaper than having a shop do it for you, if you do the test and you have no pressure while cranking the engine then your fuel pump is bad, the pump is in the gas tank, a big job and dangerous due to chance of fire if you are not cautious.
SOURCE: No heat in my 2000 ford expedition
You should check your blend door, go to the center of your dash look down towards the floor right at the bottom on the hump (tunnel area) you will see a black or same as interior color, cover it has small slits cut in it, it is held in by two expanding type plastic bolts, they do not unscrew, just pull them out, one on each side. Once removed locate the white small box with a wiring harness connected to it, a little to the right hand side. This is the stepping motor that controls the blend door. Remove the stepping motor, and reconnect the harness, look at the motor drive unit and operate the heater control knob, does the motor turn, if it does then use a mirror and look at the drive end of the blend door itself, it is probably broken. If the door is broken, this repair just got difficult, the entire dash will have to be removed to access the environmental station, once accessed there are about 10 screws that hold the top cover on the enviromental station, undo these screws and remove the top cover, then you can remove and replace the blend door. If you are not comfortable with this difficultly level in repair I suggest you seek out your favorite local shop. removing the dash is not easy, there are alot of screws, some in very difficult places to reach. Testing the motor is easy. I hope this helps, let me know.
SOURCE: 1998 Expedition: 2000 Ford Expedition I smell antifreeze with heate...
If you smell antifreeze it may be 3 possibilities: 1. you may have a leaking hose/hose connector , or water pump. 2. your heater core is bad and needs replaced. Unless you know what you are doing I would highly suggest taking to dealer for heater core replacement. The dash and steering colum has to be removed to get to the heater core. This is not an easy job believe me (about-900-1200 job). If you have your heater core replaced then also replace the climate control door. This is good preventative maintenance and also a a dollar saver. I would have a pressure check run on your radiator as a first thought. All you may have is a bad hose and that can easily be replaced.
SOURCE: 2000 ford expedition. trying
I have a 98 Expedition an had the same problem try waiting for the theft light to stop blinking then give it a try it worked for me. Good Luck!!
SOURCE: 2000 ford expedition wont start,security
Your vehicle is equipped with a passive theft deterrent system that utilizes a "pill" embedded in your key along with a receiver contained in the steering column. If the system doesn't recognize your key, the vehicle will crank but not start and the theft light will flash rapidly. If you have another key, try it. Otherwise, you're in for a trip to the dealer where they can either reset the system or troubleshoot it further.
Good luck.
Thank you very much....
