Question about D-Link Express DCS-900 Network Camera
D-Link DCS 900 Network Cams: MAC Address error
Setting up 4 cameras. Have added them in IPView SE, and they are monitoring/recording. However, I need to set up for remote access, also. Whenever I attempt to "Add Camera" in Admin app I get an error message that tells me I am entering an incorrect MAC address. I know the MAC addresses are correct. I got them off the cameras and compared them with info in IPView SE. What am I doing wrong? And do I even Need to set up the cameras in Admin app to gain remote access?
    Problem Solver:
  • 10 Answers
Hi
The IP cameras need to be configured based on IP
You will also have to clone the same IPs on the router page
Posted on Jul 08, 2017
5 Suggested Answers
  • 181 Answers
SOURCE: How to set Static local IP Address for D-link DCS
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
Posted on Jan 04, 2010
  • 4 Answers
SOURCE: DCS-1000w through Dlink DIR-655 router
These cameras are touchy. Hold the reset button on the back in for about 20-30 seconds. Bring up the CD software you got with the camera, it should spot the camera right off and you can configure. That seems to be the only way I can communicate with this model. After setup, then browsers, etc seem to work fine. I would also download the latest Firmware and update.
Posted on Jan 10, 2010
  • 569 Answers
SOURCE: D-Link DCS-900W The camera will not pick up the wireless network.
The most straightforward way is to run the setup again. You will get to a screen that says your IP address may be invalid.
At this point you need to answer 'yes' to 'would you like to change your IP address'
You now need to enter an address that corresponds to your network. You should choose an address that has the same numbers in the first three groups e.g. 192.168.xxx and assign a number in the last group, e.g. 99
So if your network is based on 192.168.2.xxx i suggest you assign the address 192.168.xxx.99
I hope this helps.
If not, please respond on this site and I will try to help further.
Posted on Feb 20, 2010
yooperbud
  • 8637 Answers
SOURCE: I cannot see my camera on the network. I have
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
Posted on Sep 23, 2010
I am looking for someone to repair 4 DCS-6620 cameras. It isn't a sofware problem it is hardware that needs to be fixed. Example camera came off base.
Any luck?
I have 7 of these that need service for one reason or another. They began to fail shortly after the warranty ran out, and have recently begun to fail much more quickly.
Next time, before I buy 62 cameras, I'll make sure I'm dealing with a company who services their product...D-Link tells me they simply don't and that these are $900 DISPOSABLE units.
Please let me know, too, if you can fix these (various problems depending on camera include include motors not working, no image produced, etc)...I can send them wherever they need to go.
clipalong at yahoo dot com
Dec 30, 2010 | D-Link DCS-6620G Network Camera
How to set Static local IP Address for D-link DCS 5220 IP Camera? Am using Linksys WRTG54 Router, with SSID & WPA. I had set the D-Link DCS wireless to use the same SSID and WPA, but once I plug out...
Hope this helps
Nov 24, 2009 | D-Link DCS-5220 Network Camera
What is the default ip address of D-Link DCS-3220 ip cam ?
Hello
The D-Link DCS-3220 have DHCP, that means it gets a automatic address from your router.
IT doesent have a STATIC ip, if you not set it manually.
To configure your D-Link DCS-3220 CAM and find the IP you need to install this program.
Install Wizard You need to unpack it first.
Connect your computer and cam to same router and run the program. Then it should find your cam so you can configure it and see what ip it get your you set.
Then you can browser to the cams IP.
Here is the manual and instruktions for you CAM
Here is Quick install guide
Here is you Dlink cam site to get firmware updates and more.
Hope it works.
Jul 09, 2009 | D-Link DCS-3220 Network Camera
Is it possible to record the streaming video on DCS-3220 ? and if yes how to configured the streaming server ip ?
I had a similar issue trying to feed a live stream to the web with a dcs 3220, I found that I had to use this IP configuration; Ip address is XXX.XXX.X.X/cgi-bin/video.jpg then use "jpg pull" from the web server. Hope this helps you let me know http://troyster.com
Jan 26, 2009 | D-Link DCS-3220 Network Camera
DCS-3420 SecuriCam Install
Normal 0 Did you install the software with the camera connected tothe computer? Disconnect the camera from the USB port and reinstall thesoftware. When the program asks you to connect the camera, do so, and itshould work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chaton line after you install , either Skype or a messenger program.
Aug 23, 2008 | D-Link DCS-3420 Network Camera
Wireless installation for DCS-5220
Plug in the network cable first and make sure the following settings are correct:
1. SSID is the same and set to broadcast
2. You are using the same WPA AES password as the router (or WEP password if you are using WEP)
3. The wireless antennae is connected
4. The camera is located not to far from the router
After that, remove the network cable and restart your camera.
May 19, 2008 | D-Link DCS-5220 Network Camera
Apr 12, 2008 | D-Link DCS-1000W Personal Web Camera
DCS reset
Push the reset button on the back of the camera
Oct 05, 2007 | D-Link Express DCS-900 Network Camera
D-Link Express DCS-900 Network Camera Logo
361 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
