Question about Car Audio & Video
I have a new fault developed with my Nissan
I have a new fault developed with my 2002 Nissan Terrano. The Speedo has now developed a fault and doesn't work, the needle now points directly down as if it's gone over the maximum limit and is just hanging there!
Strangely enough the rev counter that used to point down and didn't work, has now decided to move to the under side of the restrictor pin. The digital clock, milage and trip counter went off for a moment and after a re-start worked fine again. Could this need a new/replacement dashboard fitting or could it be a short circuit when starting?
Any help you can offer would be much appreciated. Thanks in Advance.
  • studio290 Jul 17, 2009
    Good advice, until I can get a replacement I've gone for a temporary fix by removed the bottom panel above the drivers pedals, then the speedo surround and then the clear plastic that protects the dials.
    I then glued a small pin on each of the two dials (speedo & rev counter) near the centre and in line with dial when it's at the resting point this limits the distance that it travels by restricting the counter balance at the back end.
    It's unlikely that I'll be travelling at a speed of over 80 MPH or in excess of 4,500 RPM and so far it works. It seemed that after a few tests the power surge at start-up causes the dials to spin and not return, this should fix the problem.
    I used small nails about 10mm long and covered them with black permanent marker, it looks like they are part of the dial.
  • 3,600 Answers
You need to replace the speedo head assembly nissian has had major problems with them, cost $220.00 new.
Posted on Jul 16, 2009
I have problem with my Nissan terrano 2 mechanical gearbox. It's hard to put to 1st gear. From 1'st to 2nd, 3rd, 4th, 5th, are also hard. Is it necessary to change clutch?
not a clutch problem unless you have just done a clutch kit change
more likely a hydraulic clutch problem ( air in the system) or master cylinder needing replacement .
if it is a cable operated clutch , replace the clutch
Dec 14, 2016 | Nissan Cars & Trucks
Speedo keeps dropping intermittently for long periods can anyone help
Peugeot 406 (1996 - 1998) - 98. Speedometer fault ' Technical ...
www.honestjohn.co.uk > Back Room > Technical matters
Sep 16, 2002 - My 406 2.1DT developed an intermittent speedo fault at about 44000 ...It tends to stick at 2000 or occasionally drops to zero for no apparent reason. ... helping me resolving my speedometer problem on my 406 3.0 v6 1999. Peugeot 406 (1999 - 2004) - 00 2.0 intermittant fault
Feb 10, 2010
Peugeot 106 (1991 - 2002) - 02 1.1 Speedo Problem
Feb 24, 2009
Peugeot 406 Speedo problem ' Technical matters ' Back Room ...
Oct 20, 2003
Ford Focus (1998 - 2004) - 1.8 petrol - Speedo drops to zero ...
Aug 6, 2003
More results from www.honestjohn.co.uk
Sep 29, 2015 | 1999 Peugeot 406
Nissan terrano owners club
what fault code do you have. If you changed the crankshaft sensor you also need to change the camshaft sensor, they go hand in hand.
Aug 06, 2014 | 2005 Nissan Terrano 2.7
How to get the abs light to go out on a 1996 nissan terrano
Get the ABS system fixed, that usually turns the light off. Get the computer scanned for the fault codes and work from there.
May 19, 2014 | 1999 Nissan Terrano
Nissan Terrano Radio Fascia
Your best bet is to get your yellow pages out and call your local junk yards and see if they have one,they are high dollar from dealer.
Dec 07, 2013 | 2002 Nissan Pathfinder
Nissan Terrano Diesel 55 plate engine management light comes on 10 mins after first journey and sounds like a diesel knock although does not seem to effect performance and there is no excessive smoke.
Probably you might face a problem on the injection pump with the Advance or retar positioning,and I believe that is controlled by the vehicle ECU. The Diesel Knocking you receive should be this fault.
Nov 02, 2013 | 2005 Nissan Terrano 2.7
1998 terrano immobiliser fault wont start
hi, i have nissan terrano wen i switched on engine light flash and start engine its start then go of.nissan terrano patrol engine
Sep 06, 2012 | Nissan Sentra Cars & Trucks
1999 nissan terrano diesel turbo is lacking power , brand new fuel pump and comp chip installed and has run like **** since, has been put through comp diagnosis but no fault showing,(is very slow 2 pickup...
Possibly the "Mass airflow sensor". I had a similar problem, basically the car behaved like it didn't have a turbo and was really slow. Unfortunately the Mass airflow sensor is expensive, about AU$800. Only failed once several years ago. Hope this helps.
May 13, 2010 | 1999 Nissan Pathfinder
Nissan Terrano II 2000 Speedo not working
you can remove the speedo from the dash flip it over to where you can see the gears in side and the contacts try cleaning them out real good with spray air for computer keyboards, the spray a little lubricant on them put back in and see if this helps it move a little better.
Aug 29, 2009 | 2000 Nissan Pathfinder
Car Audio & Video Logo
437 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
