Question about Dishwashers
Cant get the door to open. seem to be stuck upper right hand side
    Sergeant:
  • 296 Answers
Hi
chek whether there is any hinge tht is loose on the side of the door or a catch tht u can sqeeze ,try pulling on door while trying to trip release.The only other suggestion,which I have had to do is YANK the door open.You will break the catch but it is easily replaced.
hope u will b helpfull
regards
Posted on Jul 16, 2009
Back latch wont let me open door due to being broken how do i open it
Take the molding off and you can put your hand in there and open it manully wile some one is holing the door lach so you can do one side at a time or both
Feb 27, 2013 | 2000 Plymouth Grand Voyager
I cant believe i cant find the model # of this fridge but anyway , i installed a new water filter a purr #4396841 and did it according to the instructions , did everything but the red light remains, wonder...
The model # is located inside refridgerator door on the upper right side panel.To reset the light you have to open fridge door and by the light there is a button you have to push in the button 5 times in 10 seconds to reset.Hope this helps if so give us a 4 thumbs up. THANKS
Mar 03, 2011 | Whirlpool GD2SHGX Refrigerator
Printer says "Open Door Clear Cartridge Jam" How
You might wanna try removing and reinserting the cartridges and make sure that they are properly fitted in.
Sometimes cleaning the cartridge and the carriage where you took out the cartridges from with a damp lint free cloth does the trick.
If you still have that message, open the cartridge access door.
If the carriage is stuck at the right side of the printer, move the carriage to the left side by hand. If it's stuck on the left side, try moving it by hand in the right side of the printer. Then while the printer is turned on, unplug it from the wall outlet and then plug it back in.
If the printer does not turn on, use the power button.
Try printing again.
Feb 03, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Small pieces of paper are stuck and cant be reached
Paper is probably stuck under the fuser, follow these instructions to remove the fuser:
Fusing Assembly Removal and Replacement
1. Remove rear cover:
a.) Extend input extender assembly
b.) Remove three screws
c.) Separate the rear panel from the main cover, pulling the lower corners away from the printer first. Then,
insert small flathead screwdriver into the openings at the top upper corners releasing two tabs,
remove cover.
2. Remove EP door assembly
a.) Along the left door hinge there is a flex point, firmly press tab inward to release door.
3. Remove main cover
a.) Remove rear cover
b.) Remove EP door
c.) Remove memory cover
d.) Remove two screws from top of printer
e.) Grasp two lower front corners of printer and pull gently outward, lift cover straight up and off
4. Remove fuser
a.) Remove exit roller (unlock white bushings on either end)
b.) Remove right hand cartridge guide (depress one locking tab and slide forward)
c.) Remove two screws from delivery assembly (fuser cover) and remove
d.) Remove two screws from pressure plate, (metal) unlock two retaining tabs and remove
e.) From right side of printer, remove cable guide, and fuser cable from DC controller
f.) From left side of fuser, remove thermistor cable (white) and remove fuser
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 02, 2011 | HP LaserJet 5L Printer
The doo seems to be stuck down...like the upper
On the side of the motor unit you will find the 'down limit' adjustment. Turn this in the opposite direction of the arrow printed on the cover. It may help if you remove the cover and you can see the limit adjustment assembly. It will help you understand the problem.
Dec 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
I can't delete spam from my spam folder and I cant empty trash.....
Going to guess that you're in "Mail Classic."Try switching to Beta.On right hand, upper side of screen (following "Hi Your Name"), select "All new mail."
If that doesn't work (and it should) and you want to return to "Classic:" On upper left hand side of screen (Hi Your Name), just click on Mail Classic and, viola, you're back.
Apparently, Classic is experiencing some problems with MS security updates. The Beta version seems to be OK,
Jan 02, 2009 | Yahoo Mail
Belling IDW 603 dishwasher
You can cancel the programme at any point by holding down the last button on the right hand side for about 10 seconds until it clears (its the same button you use to get it going again when you open up the door).
Mar 05, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Front door will not open
On the bottom right-hand side of the washer, there should be a door that contains the drain cleanout. Open the door and in the upper right-hand corner of the opening, there should be the end of a plastic handle. It may barely be showing, so look closely. Pull it down with your fingers or a plyers and your door should release.
Feb 22, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Right Hand door swings open too fast
On the bottom of the door there is a part called a door closure kit.It operates like a cam. There are high and low points on the part that aid in the opening and closing of the doors. Do-it yourselfer project.
Nov 10, 2007 | Maytag MFD2560HES Bottom Freezer French...
Dishwashers Logo
Top Dishwashers Experts
