Question about Hayward SAND FILTER, PRO SERIES
Dirt comes back thriugh the return when I vacuum
When I vacuum the pool you can see the dirt come back out the return in the pool. My husband thinks we need more sand in the filter. we changed the sand 2 years ago and added the reccomended amount at that time.
  • 93 Answers
If your pool is clean its not sand when we vac customers pools we put vac in pool and put vac hose over pool take a wet vac put on end of hose outside pool keep it on only long enough to get water flowing save your filter and water if you want to vac through skimmer make sure you are in filter mode good luck
Posted on Jul 17, 2009
  • 580 Answers
It is time to change the sand again
Posted on Jul 16, 2009
    Problem Solver:
  • 5 Answers
Go get it fixed or u might have 2 get a new 1
Dirt devil pool vacuum slow stays on pool sides
go to http://dirtdevil.com/support/ get the support section and download manual, troubleshooting, video for troubleshooting, and fix it.
God bless you
Sep 16, 2012 | Dirt Devil Vacuums
Dirt devil pool vacuum wont move
If one of these pool cleaners is not working, you likely have an obstruction in the flapper. That would explain why you have suction and no movement. With the pump off, turn the cleaner upside down and check for any twigs, rocks, etc. in the flapper. If you don't see anything or see something you can't reach with your fingers, remove the base plate with a flat head screw driver and check there. The base plate is where the waste is collected.
Jul 09, 2010 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
Replacing the drive track.
The tracks for the Dirt Devil Rampage pool cleaner are the same as the AquavacTigershark. Simple look for the parts for the Tigershark. Its the same exact thing.
Jun 20, 2010 | Dirt Devil Rampage Robotic Pool Cleaner...
My resently purchased Dirt Devil pool cleaner vacuum for above ground pools does not have any suction. It was assumbled the exact way the manual said. What's the problem?
Sometimes u have to use the return water that enters your pool to fill up the hose with water u use to get all the air out of it, its kinda like priming it. or u can submerge the hose all the way. And if that still doesn't work then sometimes giggling the hose might get it to start suction
Jun 02, 2010 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
I changed the sand and i can only vacuum about 2
Try consulting the owners manual for these pool filters. It will give you a lot of info in the settings that your filter needs to be on to do specific tasks. I really think that it will help you get this straightened out.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 21, 2010 | Hayward SAND FILTER, PRO SERIES
How to set up a d2000 automatic pool vacuum
Here is a copy of the users manual for these above ground pool cleaners. It has detailed instructions and pictures for set up. This should help.
http://www.backyardcitypools.com/images/BWP/Dirt-Devil-D2000-Manual.pdf
May 21, 2010 | Dirt Devil Above - Ground Auto Pool...
After replacing gasket on filter vacumed pool
I would suspect that there is a fault in the filter, a bnreak in the filter elements, a bad alignment, a colapsed support. something that is letting the dirt get back in to the pool
Feb 11, 2010 | Hayward Pro Series 18" Above Ground Pool...
NO SUCTION AFTER VACUUMING POOL
Did you use a trash plate? If not you have something stuck in the pipes and need to use an air compressor and blow from pump with main closed. Debris should shoot out!
Sep 25, 2009 | Hayward SAND FILTER, PRO SERIES
D.e. earth pool filter returning dirt to pool
The flow tubes inside the filter canister are torn and letting dirt pass. The repair is simple and can be done by someone with a few hand tools. Download the manual for the filter here:www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
You'll only need to replace the ones that are ripped, and the cost runs about $3 - $5 each. Search around on Google for a supplier or try a local pool dealer.
Jun 08, 2009 | Hayward EC-40 DE Pool Filter with pump
Hayward SAND FILTER, PRO SERIES Logo
940 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
