Question about HP PSC 1410 All-In-One InkJet Printer
I am trying to print and it just says error - HP PSC 1410 All-In-One InkJet Printer
  • 62 Answers
Hi and welcome to Fixya!
try to download driver and re install
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=219&lc=en&cc=us&dlc=en&product=441115
Thanks for using FixYa!
Posted on Jul 18, 2009
49.38.07 error
Best way to test this issue is to unplug from the network, power off machine and back on then see if the error comes back. If it does not then try some internal test prints, if they print OK there is a corrupt print job being sent to the printer causing it to have the 49 error code.
I would clear all print queue jobs then upgrade firmware, this should fix it, printing from some websites cause this error, try another brouser if possible, Chrome etc.
Aug 24, 2014 | HEWLETT PACKARD - LASER JETS CE708ABGJ...
49.4 C18 laserjet 4345
49.XXXX is a fatal catch-all error. Could be firmware problem, network, print job. If the error occurs when you try to print, clear the print queue. If the error occurs when the printer is just sitting idle, reseat the formatter. Try powering on without the network cable attached. If it still happens replace the formatter. Could be a corrupt print job being sent to printer. Print something else.
Mar 28, 2014 | HP LaserJet 4345mfp Printer
Laserjet 2605 49 error
Error 49 is a firmware error. Try following these steps:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 10, 2014 | HP LaserJet 2605dn Printer
49 error
49 error means firmware error..
solution:
3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certain print job, try upgrading the printer driver and / or firmware.)
5. Remove all EIO devices from the printer (Jet Direct cards, hard drives, etc.). If 49 errors goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing.
6. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error.
7. Remember to reconnect all cables that connect the printer to the network or computer.
8. If the error persists, replace the firmware DIMM.
9. If error persists, replace the formatter.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 11, 2012 | HP LaserJet 3055 All-In-One Printer
Received the following message when I tried printing - "System Error. The printer failed to print due to a system error. Try printing again. If unsuccessful turn Windows off and reprint." Can you sugg
Turn it off and unplug it for about 30 seconds. Plug it back in, turn it on and try printing a Self-Test (Setup, 2, 5). If this works, try printing your document again.
Apr 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
PCL XL error
try to go to property then setting device button PDL and try to put pcl 5e
Sep 11, 2008 | Office Equipment & Supplies
Printing error on mac
hmmm..sounds like the printer drivers are unhappy. go to www.lexmark.com and get fresh ones for your OS..and remove the old ones first, if you can.
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Lexmark X2500 All-In-One Printer
HP PSC 1410 All-In-One InkJet Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
