posted by daril on Nov 18, 2007
hey. i have a 97 maxima. the alt. is good but is not charging the batt. belts are tight and fuses checked. the batt. light , brake light & the check engine light are all on what could the problem be?
Solution #1
posted on Nov 18, 2007
with that case are you having problem starting you car. if you hardly start your car then it really is not charging!
check for the relays and also the ammeter too. clean wire connections, rust/corrosion limits current flow and heats up wiring which may lead to melting of the insulation of wires then short circuit.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
Black & Decker SmartGrind Deluxe CBM7B Electric Burr Grinder
Bosch MKM 600 Blade Coffee Grinder
Bosch MKM 6000 / MKM 6003 Electric Blades Grinder
Braun KMM 30 Electric Burr Grinder
Bosch MKM 6000 Electric Blades Grinder
Cuisinart Thermal DGB-600 Grinder
Breville Conical Burr Coffee Grinder - Stainless-Steel
Can you Help with these Coffee Grinders problems?
Bosch 6000 Cofee Grinder
I dropped my bosch coffee... Answer This...
Black & Decker CBM1 Grinder
Black and Decker CBM1 coffee...
is there a reset button for... Answer This...
Cuisinart Supreme Grind DBM-8 Electric Burr...
I have a Cuisinart Burr
I have a Cuisinart Burr coffee... Answer This...
Krups GVX2-12 Electric Burr Grinder
My Krups GVX2 grinder sounds
My Krups GVX2 grinder sounds... Answer This...
Repair Service
Find Coffee Grinder Repairman Near You:
