I need to replace my floppy drive on a yamaha psr 9000 keyboard
I need to replace my floppy drive . how do I do this and How do I get at it and remove the outer casing
M-Butkus and anonymous: he doesn't mean a floppy drive in a pc, he means a floppy drive in an old yamaha keyboard.
danboy144: Flip over the keyboard (i know it's heavy, got one myself), unscrew the 4 screws on the small panel, and remove that, then you unscrew the rest of the screws, and pull of the bottom cover, then you can access the floppy drive and replace it. Thats what i did, only, i changed it to a USB Floppy Drive Emulator like this: http://www.ipcas.com/products/usb-floppy-emulator-fdd-to-udd.html
Posted on Jan 05, 2013
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 68 Answers
I found a site where you can buy an external Floppy drive for about 11 dollars i hope this helps!
Posted on Nov 11, 2012
  • 73 Answers
Why.. get a USB floppy.. if you go inside a PC and pull a wrong wire your PC will be toast. Get a USB floppy. Why are you using floppies anyway? Get a USB stick for $8, way less then a replacement floppy and much safer.
Posted on Jul 25, 2009
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
Yamaha psr 9000 keyboard
Try dusting the keyboard with talcum powder. Shake the unit around a bit, so it gets under the keys. That will likely help "lubricate" the keys and quiet down the noise.
It works on my piano. Nwo all I hear are the sour notes I hit!
Jul 27, 2014 | Yamaha Music
Floppy drive for Yamaha PSR 1000
What do you need a floppy drive for, those are obsolete?
Mar 19, 2017 | Computers & Internet
Power comes on but the psr 9000 yamaha does not boot up past the first page
The unit probably is detecting an error during the power on test... A long shot MIGHT be a button or key that is stuck on, that is sensed as being pressed. See if all the buttons are completly up. If the unit has a harddrive, a failure of it can block the booting even though the operating software is not on the drive in these. If you find a button that is sticking, put a tiney bit of CRC226 around it with a Q tip. You can get the CRC226 in the electrical dept of Home Depot. You just want to wipe the edges of the button to lube it a bit.
Apr 11, 2011 | Yamaha PSR-E413 Portable Keyboard
Where can I obtain a manual for the Yamaha PSR 9000 keyboard
try here - http://download.yamaha.com/search/product/?site=usa.yamaha.com&language=en&category_id=16084&product_id=1063469
Mar 23, 2011 | Audio Players & Recorders
I have the manual for the keyboard but unfortunately the disc has been lost. Where can I obtain another disc?? Can you help??
You should be able to order the disk from Yamaha America.
Call 1-(714) 522-9000 and ask for "parts".
Dec 12, 2010 | Yamaha PSR-295MS Portable 61-Key...
Model: PSR 620. The floppy drive is not working and needs to be replaced. Original floppy drive uses DS DD 720kb floppies. Where can I get a replacement drive? How much does it cost?
The replacement cost of these is prohibitive often greater than $200.
You should try to clean the heads in your drive and see if you can spot a mechanical problem. Clean the heads carefully with 91% isoprophyl alcohol and Tube Gauze on a tongue depressor. Be very careful.
Aug 09, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
When I load a floppy with music styles into the
Not sure about your particular keyboard, but on the Yamaha Tyros the style will NOT start rhythm until you select start AND hit a chord.
The style doesn't know what chord to start with until you trigger it.
SOMETIMES the style has to be moved to a user space...
One has to read and then DECYPHIER how to work these synths... Spend a little time with the user manual, as hard as it is to understand.
Jan 12, 2010 | Yamaha Music
I need for :yamaha keeboard psr 9000 :danish manual
hej I asked my lokal store. thank ouy for answer. best regards poulc
Jun 24, 2009 | Yamaha Portable Keyboard
LCD YAMAHA PSR2700 KEYBOARD
My Yamaha PSR 2700 LCD lighted, but no can not see message (text). Any help is graceful to me.
Tom
Apr 25, 2008 | Computers & Internet
Computers & Internet Logo
859 people viewed this question
David Payne
David Payne
