Question about Sony Playstation 3 (PS3) Console
When i turn on my ps3 the xmb menu wont show....
When i turn on my ps3 it turns on ok but the xmb menu wont show...it wont show anything to be in fact.. its just black but its on, and my controller wont connect to it...not even when connected to it... and it takes longer than usual to turn off
Am sure about the computer part but for the xmb i can help reset ur ps3 by turning it on then turn it off by holding the buttonthen it back on by holding the power button it should beep pause and beep 2x this will reset ur display option back to normal then ur cables make a difference if ur using a SD TV use regular cables if HDTV use hd cables only on hdtv if use on SDtv it won't display or ur ps3 is set to an hd setting like 1080p it won't display on a sdtv so reset ur ps3 by holdin power button hope this help u
Posted on Aug 31, 2009
When i put my ps3 games in they don't show up in the menu. nor do they auto start. the same thing happens with movies?
You can enable or disable auto run in the settings area on the XMB, but I've never heard of the disc not showing up at all. Even if the disc was unreadable, the PS3 would say "Corrupted Data" or something. You should go through your PS3's settings and see if there's anything that's not right. Maybe there's a "Hide disk" option enabled. Sorry I couldn't help more.
Apr 10, 2011 | Sony Playstation 3 (PS3) Console
Ok my ps3 will read blu ray movies but will not read my games
Unfortunately a similar issue happened to me as well, and I had to send my PS3 in for repair (hardware issue; the disc drive broke). But maybe what I was told to do will work for you! Here's what I tried.
Easiest solution? Make sure your system is updated. Who knows, maybe it's a firmware thing. Go to XMB > Settings > System Update and run it.
For the next couple of things, you're going to want to backup everything on your PS3. The Backup Utility can be found in the System Settings Menu on the Settings Menu on the XMB menu (XMB > Settings > System Settings). More info on how to backup your information can be found on the Playstation website, found here.
With your data backed up, try the different options in Safe Mode. This link will show you how to access it. Try options 2, 3, 4 and 5, in that order, and see if it's reading discs in between each one. Anything after 2 will delete your data; thus the need to make a backup.
If that doesn't work, either try the online Knowledge Center (but it'll probably tell you do try things I've already outlined here) or send in your PS3 for repair (if it's under warranty, it's free!)
Hope you're able to fix it! Sending it in takes forever; you won't get your PS3 back for a month or two.
Mar 24, 2011 | Sony Playstation 3 (PS3) Console
XMB not showing up
Sounds like your cpu has overheated and separated from the board, causing it to freeze before loading the xmb.
0 false 18 pt 18 pt 0 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin;} Try CPR in New York City. They are faster than the manufacturer, and cheaper! They have a usual turnaround of 1-2 business days. And if you become a fan on their facebook page, mention it and you will get a 10% discount.
Here is the link to their facebook page, it has all the info you need.
http://www.facebook.com/pages/New-York-NY/Cell-Phone-Repair-NYC/312054784441
Hope it helps!
Jun 03, 2010 | Sony Playstation 3 (PS3) Console
My ps3 doesnt show the sign in menu
man lsn, Turn your PS3 ON from the back just red light on ok, now HOLD your finger on the I/Q keep pressing it until you hear( 2 BeeP )a menu will appear go to Option 5. Restore PS3 System,
Mar 04, 2010 | Sony Playstation 3 (PS3) Console
How can I get my ps3 to play dvds, cds, and ps3 cds
For cd's go in the xmb to music, for dvd's and blu-ray movies goto movies in the xmb.
Game blu-ray discs will be started from in the game menu in the xmb.
The option run automaticly should be turned on in tehe settings of the ps3 by default, else you have to start them manualy, as described above.
Also read the manual that came with the ps3,
it holds manny answers to alot of your questions that may arise further on.
You can find the manual also here:
http://www.playstation.com/manual/pdf/CECH-2001A-2.75_1.pdf
Succes.
Sep 09, 2009 | Sony Playstation 3 (PS3) Console
PS3 XMB menu doesn't show up.
That's not too hard to fix.
Check out my guide here:
Pay attention to #3.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
Wont run correctly
It sounds like a system file error due to trying to hack background, so check the CSS template and the theme.css to see if they are present in the theme folder. You will have to take hdd out and run on a pc to do this, you can find how to remove hdd by looking on search engine. If you get a 403 error, that means you are not allowed access. You will have to delete and reload the file from a known working ps3 hdd.
Jan 26, 2008 | Sony Playstation 3 (PS3) Console
Xmb menu
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option
Jan 08, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
715 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
