Question about ICOM Informatique Icom IC-F21 16ch UHF radio
Hi, I have a reception problem with my T8500 two-way radio
Very bad reception even at close distances!
  • fishgrn Nov 18, 2007
    Can changing channels improve reception on my T8500 two-way radios
  • muliawarman Feb 03, 2009
    Icom IC-F21 bad reception. I adjusted the BPF T1 up to BPF T4 automatic and manual by software but problem can't solve. Any suggest for me ?
    Problem Solver:
  • 12 Answers
First you need to find out how the radio is performing. If you have a freq counter, check to see if radio is on frequency. If not on freq then you need to send it to a tech with a service monitor. If radio is on freq and has the right amount of TX watts then the problem will be much simpler. The radio might just need a tune up, some techs do this for a nominal fee. Don't try this your self if have never worked on radios, you will damage the radio.
Posted on Aug 08, 2009
  • 55 Answers
Make a try between lower middle and upper channels
Posted on Nov 18, 2007
T8500 Backlight
Here is a link to the user guide:
I did not find anything mentioned about the backlight function. However, on other TalkAbout models the backlight will automatically illuminate when you press any of the buttons other than the PTT and the musical note, and then the light will remain on for 5 seconds before automatically turning off. I do not know if this is the same on the T8500.
Best regards.
Feb 22, 2013 | Motorola T8500 Two Way Radio
Cannot hear transmisions all the time. changed batteries to regular alkaline from pack to see if the battery were bad. this did not change the transmissions problem. need help.
You may have one of the following issues:
1) Programming of special features is inhibiting communications. Reprogram the radio(s) back to a basic mode with the special features, code and Qt filter (if any) turned off (zero). Then check to see if communications improves.
2) You could have a Transmit problem with the other radio. This could be caused by a bad or low battery or even a sticking PTT. Try trading the batteries with a known good radio and see if the problem changes or moves to the other radio.
3) Your radio could be failing. If you have changed the batteries to known good batteries, and tested the radio with more than one other radio, and you do not have a programming problem, you likely have a radio which is failing.
Best regards.
Sep 15, 2010 | Motorola T8500 Two Way Radio
Radio reception
Cb radio is line of sight. If there is a hill in the way, or some other kind of structure it will block the radio waves.
But also, radio waves, will bounce of the ionosphere and come back down.
So whats probably happening is...
You hear people close because they are near. You can't hear some one some what far away because of hills or something, but you talk to people far away because the are within range of the radio waves bouncing back down to them
Jul 10, 2010 | Cobra 25 WX-NW-ST 40-Channels Base CB...
My cb radio has good reception but only for a short distance, why ?
Make sure your squelch is not on, keep it all the way to the left and the RF Gain must be all the way to the right...
May 21, 2010 | Cobra 29 LTD CB Radio
18 miles max range but actual it can transmit and
The reason for this is due to various possible conditions. The first being obstacles in the operation range of the unit. IE> hills buildings trees ect. This can greatly reduce the actual distance the unit will work in. The 18mile max is probably a rating that would apply in the best opt. scenario. You would have to be on a flat terrain with no hills or valleys,no trees or buildings for the unit to reach the max distance. In dense areas of trees,buildings or uneven terrian you wont even come close to these distances. Second: any unit RF unit that is held in your hand or close to your body does cause the antenna to detune to various degrees the amount that it does depends on how well the unit has been designed. The more it detunes the less resonated frequence is recieved and amplified making for a weaker signal. In conclusion for the best long range reception be clear of as much surronding interference as possible and as high a possible above any elevated terrian
Jan 17, 2010 | Motorola T8500 Two Way Radio
T8500 no recieve transmit vibrates when PPP is pressed
Try checking the vibra call settings for your vibrating issue. Also, as for the radios not communicating with one another you should check the programming of the frequency, interference eliminator and the Qt filter. All radios must be identical to work together.
Apr 27, 2009 | Motorola T8500 Two Way Radio
Problem with Motorola t8500
Check your Qt filter setting. It works best in the "off" position.
Jan 17, 2009 | Motorola T8500 Two Way Radio
ICOM Informatique Icom IC-F21 16ch UHF radio Logo
388 people viewed this question
Top ICOM Informatique Radio Communications Experts
BJ Russell
Are you an ICOM Informatique Radio Communication Expert? Answer questions, earn points and help others
