SOURCE: Solid yelow led and the red led is flashing
Check your manual or:
http://www.toshiba.ca/web/pdf/5056HM66_EN.p.pdf
Use the quick restart procedure
SOURCE: philips tv 32pw9617 wont turn
I had this on this model a year ago
Your power supply has blown
I had to courier it off to the Phillips service centre to have it replaced, they got it back to me the next day (this was in Sydney)
Hope this helps
SOURCE: Wont turn on
Your TV's safety circuit or programming may has caused your system to shut down to prevent further damage. You may also want to check the lamp for your tv if it is secure or loose or covering has damage and may need replacing. If that checks out OK, I am unsure if there is a rest button on the WEGA but if it does not you can reset it by unplugging the device for at least 4 hours or overnight.
SOURCE: Plugging in my Mitsubishi 62327
The problem is either from the lamp and ballast or from the power board (power problem).
When the LED shows green, it means it is lamp problem, but since you have replaced the lamp and problem still persists, then it means it is a power problem. The red LED indicates power problem. You can also try to replace the ballast. The ballast helps to ignite the lamp and make it function well.
If the problem is not from the ballast or lamp, then it has to be a power problem.
The red LED is is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
SOURCE: TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
