Question about IBM Infoprint 40 Laser Printer
INFOPRINT40 LIFT FAILURE IN TRAY 1 - IBM Infoprint 40 Laser Printer
    Novelist:
  • 125 Answers
Hi dbudney:
You are having a problem with the Bell Crank. The bell crank is what lifts the paper tray in order to feed the paper. The bell crank is sping loaded and may be located on the right side of the tray inside of the printer. You will have to remove the tray to see it. Sorry i have no part numbers or manual to assist you in locating the bell crank but it is a whit plastic arm that is connected to a spring.
Hope this helps
Posted on Jul 17, 2009
How to clear c-0210 on bizhub c203
Lower Large Capacity Tray-LCT lift up motor failure..
Check any paper jam at rear side of Tray.
check the plate lift up wire and contacts.
if not
then need to replace Lift-up motor
Nov 15, 2016 | Konica Minolta bizhub Office Equipment &...
How to remove this Code Sc-46-25
1. Failure of A/D conversion board (ADB).
Check the connections between the ADB and the ICB and reseat. If the problem persists, replace the CCD (p/n 55VA-6110). Under the big glass. OR
2. A bind in any paper tray lift mechanism, not allowing the tray to raise. Repair the binding of the paper lift up plate in the offending tray. To isolate the tray causing the problem, power the machine ON with one paper tray withdrawn at a time until the offending tray is found.
Notes :
a. The bind with the paper lift up plate may be cause by the rear and side guides being too tight against the paper.
b. This problem may have been caused by the machine being moved with paper in the tray.
c. A SC18-xx code may also appear at power up.
d. Inspect that paper was properly loaded by the end user.
Dec 03, 2015 | Konica Minolta DI850 Developer Starter...
How do reset a error on a ollivetti mf3000
my dear you chek lift motor or gear broken of motor paper tray
Jul 11, 2014 | Office Equipment & Supplies
Error 071 210 xerox
Lift failure of tray 1 on some machine's
May 23, 2013 | Office Equipment & Supplies
Error CO202 Bizhub
C 0202 - 1 st tray lift up failured.
Remove the 1 st tray,in the right side located 1 screw and in copier is a paper when blocated the tray lift gear.Remove the misfed paper and push in the tray ,open and closed the right door and the copier must be ready.
C 0204 - 2nd tray
C 0206 - 3 rd tray
C 0208 - 4th tray
C 0211 - bypass tray
Good luck.
Feb 14, 2013 | Konica Minolta PRINTING - Bizhub-250...
We have a Konica Minolta Di2010 - we are getting a message on the screen that read: "A malfunction was detected. Please call your tech rep with this code: C0920" What can I do to get the...
C0920 as per the Minolta Factory Service manual is caused by a tray 1 lift motor failure. In my experience with this code, it is usually caused by paper loading in the tray or something jamming the tray. Best solution is to remove all paper from the tray. Leave the tray open an inch or 2 and turn the main power switch off then back on. The main power is on the back of the machine NOT the one on the right edge of the operation panel. Once the code has been cleared then try a test copy by using one of the remaining trays. If it works correctly then re supply paper into the top tray 1 and then see if the code returns. If it does then either your lift motor is bad or you have something jamming up the lift plate in the paper tray. You can always leave that tray open and run the machine until you can get someone out to look at it. Most of the time tho, reloading the paper in the tray will solve the code.
Good Luck and Thank You for using Fixya
WheatlandServices
Dec 16, 2010 | Konica Minolta Office Equipment & Supplies
A paper jam was not cleared in a timely manner, now the machine will only display "Error Code C0202, Call Technician" It is Saturday and I can not get a hold of anyone at our support center. How can I...
C0202= tray 1 elevator failure.
Open tray 1, check and make sure paper is loaded correctly.
With tray open, open and close front door. This will reset error code. With tray 1 open look to see if paper is stuck behind tray in back of machine, if so remove it ( this will block the lift motor for the tray).
Close tray 1, if you hear a popping noise the lift motor is damaged and will have to be replaced. Until it is replaced operate machine with tray 1 out to prevent error code.
Sep 18, 2010 | Konica Minolta Bizhub 362 Copier
I have a WorkCentre 5225 and it is telling me that I have an error (code #071-210) what is this error?
That error specifies a Tray 1 lift failure.
You probably can hear the motor lift 127K38171 when you re-insert the tray, so maybe the lift motor is bad or maybe a sensor
930W00113 is falsely accusing our motor.
Whit
Item, Inc
Aug 13, 2010 | Xerox Workcentre 5225 / Copier, With...
Error code C0202
this is a tray 1 lift up failure code pull the paper tray out and check to see if some torn paper is blocking the lift sensor look around where the paper is fed into the feed plates if not it could be a failed lift motor or sensor and they will need to be replaced
Nov 29, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
H code
not familiar with the model number but H codes usually refer to paper tray lift failure - H2 tray 2 etc.H1 tray 1- are all your trays working ?
Dec 23, 2007 | Office Equipment & Supplies
IBM Infoprint 40 Laser Printer Logo
574 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
