The Graco digital iMonitor scrambles the signal as it travels between the monitor and the receiver, making signals nearly impossible to be heard by others.
I had good experience with this product, it didn't suffer from the static noise problem.
Base unit appears to be working, but neither of the charged handsets will work. Both are showing red...
(More)
Base unit appears to be working, but neither of the charged handsets will work. Both are showing red and beeping, but will occasionally go green for a second before going back to red and beeping.
Hi, The nursery units are both on - not using both parent units as of yet. The one I am using(set to...
(More)
Hi, The nursery units are both on - not using both parent units as of yet. The one I am using(set to room 1) - has continuous beeping with a small pause in between - with yellow and red lights on front. and cannot hear anything from that room. Any suggestions - please baby #2 is on way - need to get this straightened out asap. Thanks.
One of the parent units suddenly stopped working. Only has red light and one green light. No sound....
(More)
One of the parent units suddenly stopped working. Only has red light and one green light. No sound. I was sent a new battery, and put it in, but it didn't help.
I was given the graco 2 set monitor with two base chargers from my sister in law. She used it with...
(More)
I was given the graco 2 set monitor with two base chargers from my sister in law. She used it with her daughter and doesn't need it anymore. I have had them charging for 3 days and when I turn them on, even when on or off the charger, all they do is beep. The model on the back is A3940. Patent pending # is LAPM0007A. There is only an on/off button and a volume button. Why is it beeping? Please help
Graco Vive iMonitor alarms the out of range signal every night at 12:59 am. It beeps with increasing...
(More)
Graco Vive iMonitor alarms the out of range signal every night at 12:59 am. It beeps with increasing urgency for about 2 minutes and then stops. We're not sure if some data download from our security system or satellite interferes or not. We've unplugged our wireless router overnight with the same result.
