Question about RCA G27669 27" TV
About once an hour, the audio on my RCA g27559 TV switches to static. Unplugging the set and plugging it back in resolves the question temporarily.
  • RCA Master
  • 1,229 Answers
I can only guess it is the CTC 177. You will have to remove the shield on the bottom of the tuner on board. Look for about 20 cracked rings on this tuner. There is about 20 bad grounds to resolder. Be very careful, you may have only one chance to save this tv. Use a 20 watt solder iron inside the tuner and maybe a 30 watt iron to resolder the perimeter heatsink grounds. Now take off the earmuffs and listen to the music.
Posted on Aug 04, 2009
No sound
Hi
Thanks for using FixYa. Please check the audio with a DVD player or cable box. Also try using component cables if using a RCA component cable or vice versa. Check that all of the cables are plugged into the back of the TV & MUTE button is not pressed. Do a hard reset by unplugging the power cord for more than 4 hours and power it again, then go into the on-screen-menu and make sure the sap is off and stereo in on. Also try audio from Phone and 3.5mm jacks (if equipped). If this all didn't resolves the issue then it is an Audio IC or bad speakers/speaker connection. Please do accept the solution if the issue is resolved else revert for further assistance.
Thanks
Rylee
Aug 30, 2010 | Samsung SyncMaster 710MP 17 in. LCD...
TV was fine and then suddenly volume went off. Also the controls for channels and volume are not working
Hi
Thanks
Rylee
Mar 11, 2010 | Hisense Televison & Video
Our tv's volume stopped working
Hi
Thanks for using FixYa. Please reset the TV by unplugging the power cord for more than 4 hours and plug it back in. Now check that the sound is coming normally from the set. You’ll need to also check these parts---Breakdown or overheating of some components of amplifier, wiring, speakers, function settings, power supply and sound detector inside the signal IC processors are fine. Go to the on-screen-display and make sure you are set for stereo audio. Please check that the on screen display is set up for internal speakers and stereo audio. Also, check any other settings that may have gotten disturbed accidentally. Make sure that all the settings are correct and that the internal switch on the back is set right. Use headphones and check if you’re getting sound through them. You’ll need to check that the issue is with the speakers, wiring or the amplifiers.
If still the issue is not resolved then check the audio chips are fine. If you’re using RCA cables then switch to HDMI and vice-versa. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 08, 2010 | Mitsubishi Televison & Video
Good morning. I've had this tv since December 2001. No major problems until now. All of a sudden I have no sound whatsoever. You hear a hissing sound and thats it. What would the problem be and how much...
Hi
If still the issue is not resolved then check the audio chips are fine. If you’re using RCA cables then switch to HDMI and vice-versa. If any of these components are gone bad then it will not cost much and worth to be repaired. Otherwise I’ll recommend that you better buy a new set as a set of this age might not be worth repairing.
Thanks
Rylee
Jan 31, 2010 | RCA F36715 36" TV
Mitsubishi ws-65807 65 inch. The sound is very low, distorted and very scratchy noise. It is not the audio exit, it has already been changed. What else could be the problem and what parts would need...
Hi
Thanks
Rylee
Jan 12, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Turned on tv picture but no sound nothin
Before you Proceed, Disconnect the Power Supply, Unplug the Cord and then try to plug in after few minutes, say 30 minutes. If the Problem persists, more likely it's a Faulty Power Supply Board.
You need to have some electronic Experience to Open the TV and then you need to locate the Board. Once you find the Board, you need to pull the wires and try to Look for Swelled / Bulged / Leaked Capacitor. You need to go to Radio Shack or Order Online and then replace that. Once replaced, that would fix the issue. Usually, Bad Caps do have Ammonia kind of odor.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 05, 2010 | Televison & Video
High audio static on all but one channel of my RCA TV
had this problem for a while only just found the cause, its either your tuner flipped out which means you just neded to retune the tv and it should be fixed if not that there was this setting i found still not sure what it is or means but you could select these letters i think there was S, BG and some other ones but i changed it to the top one which was BG and it fixed the static sound with the clear picture problem just stuff around with the channel settings and see if you have that setting hope that helped
Aug 16, 2009 | RCA Televison & Video
No audio...only static
This is caused by a corrupted signal being sent out by one of the stations you are watching. There is definitely NO PERMANENT SOLUTION to this problem. Just keep unplugging the TV.
May 13, 2009 | RCA P60921 60" Rear Projection Television
RCA 25GT511 - fuzzy picture slight static sound; wiggle coax rear mount temp resolve
There might be a bad (loose) connection in the RF isolator or the tuner (both are silver boxes. Try to unplug the coax and bend the RCA tabs in so that the connection gets firmly made when reconnected. This may help. If it does not The connector may have to be replaced.
Aug 08, 2007 | RCA 32V550T 32" TV
RCA G27669 27" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
