Question about Maytag SAV4655A Top Load Washer
My whirlpool washer model LSR6232JQ1 suddenly will not fill with water (hot or cold). It just agitates and will do nothing else. My dad can fix pretty much anything..just need to know what part to order and where I can get a manual or diagram!
Had this same problem, replaced the water inlet valve/water level switch? (blue thing the hoses connect to). Still it just begins agitation without any water. If I flip random switches (twist load size and water heat knobs while turning it on and off and flipping the lid up and down) it sometimes fills with water.
Should I replace the timer now?
Posted on Sep 18, 2012
  • Maytag Master
  • 1,606 Answers
Sounds like a bad water level switch . The diagram is located inside the control panel . There is a screw on each side corner on the back of the console , which has to be removed , then the console slides foreward and tilts back .
Posted on Jul 16, 2009
  • 534 Answers
Try to replace the water inlet valve. This valve is located in the back of the machine and in most cases is a blue plastic assemble where the hoses hook up. This can be purchased at any appliance repair shop. Good Luck Hopes it's your cure. dave
Whirlpool washer letting both cold and hot water in when I only ask for cold water...
The water valve is working. It only does as told. Faulty water temp switch or yank out the small board and clean the terminals then re insert it and see if maybe corrosion was all that it was. That is what I would try if it was mine.
Dec 22, 2016 | Whirlpool Washing Machines
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
My washer will not fill with water nor will it agitate , but it will spin out. also i dont know where the or which trap to check.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 16, 2011 | Whirlpool Washing Machines
Turn washer on, only get a buzzing sound. No water fill, rotation of agitator, nothing
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Nov 26, 2010 | Whirlpool LSQ9600L Top Load Washer
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
The cold water trickles in to fill the tub
sounds like you have checked the water coming out of the cold water so the fill valve requires replacement
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer functions but doesn't fill with water, with
if it agitates without water then the fill pressure switch is stuck , this will lead the unit to beleive its full already.
replace the water level/fill switch for the fix.
Phil
Jun 10, 2009 | Washing Machines
Maytag SAV4655A Top Load Washer Logo
141 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
