Question about HP DeskJet F380 All-In-One Printer
Solution center does not detect an hp printer and closes
My printer is an hp officejet j6450. the solution center will not open, allowing me to fax and scan. my computer is a toshiba satellite. can you help?
  • 400 Answers
Make sure the printer is on and connected to the computer.
If that doesn't help then the best is to reinstall the software for the printer.
First uninstall from Add/Remove programs in control panel and then reinstall it using the CD that came with it.
Posted on Jul 16, 2009
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
Can't fax because the fax log is full and want to know how to erase
HI...............
How to Delete a Fax Log History on an HP????
The HP printers come with the HP Solution Center software. The software allows you to adjust settings, transfer images, send a fax and make copies right from the control center instead of using the printer control panel. When you make a fax, receive a fax or block faxes, a log is kept in the HP Solution Center. You can use the software to view faxes and delete a fax log history.
Difficulty:Moderately Easy Instructions
    • 1 Open the HP Solution Center by clicking the "Start" button. Navigate the mouse to "Programs" and click on "HP" to open the drop-down box. Click on "HP Solution Center." If you have the "HP Solution Center" icon on the desktop, you can click the icon to open the software.
    • 2 Click on "Settings." A drop-down box will open up. Click "Fax Settings and Setup," which will open another drop-down box. Click "Fax Log," which will open the fax log window.
    • 3 Read the "Sent Log," which is the first tab on the window. The information will tell you the date, duration of the fax, name of the fax, fax number, how many pages and the status.
    • 4 Click on the first fax in the log to highlight it. Click "Delete" at the bottom of the window to delete the fax. Continue this step for each fax until every fax you want deleted is gone.
    • 5 Click on "Received Log" and delete each fax. Click on "Blocked Faxes" and perform the steps again to delete each of the faxes in this log that you want to delete.
HOPE THIS SOLUTION WILL HELPFUL TO YOUGOOD LUCK.................
Sep 24, 2011 | HP Officejet 6500 Wireless All-in-One...
I have a HP Officejet All-in- One. Fax won't go through
We have a Hewlett packard officejet t45 all-in-one. We recently bought a new computer that didn't have a LPT1 port, only usb ports. So we bought a usb cable and now it only prints. I then went on the Hewlett Packard website and did some searching and reading and found that our all-in-one printer requires a LPT1 port and cable to work properly. If that is the same with you, you can buy a LPT1 card with the port to install in your computer.
Aug 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
I want to fax scanned items saved to computer
hi
check if you have the HP solution center softare installed
this software allows to set the fax settings
you can also try the fax wizard or the printer's fax icon for the same that you will find in the control panel---->printers and faxes
Jul 14, 2009 | HP Officejet J5780 All-In-One InkJet...
Paper jam on HP officejet j6450
Diana,
They don't bounce well, i've tried it.
Loon in the rear for an access door.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Unable to send or receive fax over vonage/dsl
I also have vonage and this fax macine - the incoming fax was going to vonage answering machine.
I went to setup (that little button above and to the right of the OK button to "basic fax setup" and changed my rings to answer from 5 to 2. This will work for me, because I only set it to auto answer when I know a fax is inbound - you might want to adjust so you can aswwer a call if you do not have a dedicated fax line.
Good luck
Dec 05, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Henning
Oct 20, 2008 | Office Equipment & Supplies
HP OFFICEJET J6450 ALL-IN-ONE OUTGOING FAXES ARE RECEIVED WITH 2 VERTICAL PARALLEL LINES [TOP TO BOTTOM] ABOUT 2-1/2 INCHES FROM RIGHT SIDE OF PAGE.
The printer needs a cleaning - Clean the cartridges, clean the inner printer.
Reset the printer to factory settings
If the problem still continues the printer needs to be serviced
Oct 10, 2008 | Office Equipment & Supplies
HP DeskJet F380 All-In-One Printer Logo
264 people viewed this question
Seeker5211
Seeker5211
