Question about Aluratek AHDUB250 USB 2.0 Hard Drive
The PC is not recognizing the the AHDUB250 as a
The PC is not recognizing the the Aluratek AHDUB250 as a drive under "My Computer".
  • 696 Answers
Please respond with more info.
Does the drive have lights on it, if so, what do they look like and do they come on?
What version of windows are you using?
Did the drive previously work on the same computer?
Does the drive show up in device manager under USB devices? or Disk Drives?
This will help us resolve your issue.
Chris
Posted on Jul 18, 2009
How do I music onto my Aluratek ereader?
First hook your Aluratek to the computer with the USB cord that came with your Aluratek. Then make sure your Aluratek is on. Go to start menu on your computer. Open the computer file it should list your Aluratek along with your computer hard drive. Left click on your Aluratek drive. It should say open. Open it then click on the file that says the type of files you want to move. Books, pictures, mp3's. Now drag and drop the files to your open file. You can also do the same with the SD card rather than the internal memory both will show up as separate devices.
Jul 07, 2011 | Aluratek Libre eBook Reader PRO Black
How do i download things to the aluratek libre?
Jun 25, 2011 | Aluratek Libre eBook Reader PRO Black
I loaded a book on my sd card then put it in my reader then it tells me that it is incompactable I can not figure out how to read it off the sd card or how todownload it from the computer to the sd card...
First make sure your SD card is formatted for your Aluratek. You do that by hooking your Aluratek up to your computer. Turn your Aluratek on with the SD card inside the Aluratek. Go to start menu. Open file named computer. There should be your computer drive your Aluratek and the SD they will be lettered left click on the one for your SD card. It should list format. Click format. Use safe to remove hardware remove your Aluratek and SD card. Now press the reset button on your Aluratek with a paper clip or needle do not use a ball point pen. Now it should be ready to load with anything you want on it. To do that you hook up your Aluratek to your computer open the drive as stated before in your SD or your Aluratek. Now drag and drop your files into the drive you have open. It should now be compatible. I know this works I had the same issue with some of my mp3's.
Jun 15, 2011 | Aluratek Libre eBook Reader PRO Black
My computer does not recognize my external hard disk.
1.Click Start
2.Right Click on My Computer
3.Choose Manage
4.Maximaze window
5.Click on Disk Management
6. Scroll Down if necesary so you can see your External HD
7.If you can see it then Right Click on it
8.Choose Initialize disk
9.Done
10.If you see an option to format Go ahead(you'll loose whatever you have in your disk if you do this)
Nov 16, 2010 | Aluratek AHDUS250F320 320 GB USB 20 Hard...
My Aluratek fell and crashed. The hard drive inside makes the funky noise. I got a new hard drive and I want to use the same enclosure with RFID. But it is not getting mounted after swiping the RFID. ...
A fall to the floor is really serious. There is probably more damage than just the hard drive. A fall to a hard surface is like a bomb going off for a hard drive...
Mar 31, 2010 | Aluratek AHDUB250 USB 2.0 Hard Drive
Plugged alluratek ahdu350 to a mac, and the mac doesn't recognize
Firstly make sure You are not connecting it via a hub or extender but directly to motherboard ports [ ports "sticking out" of Your mac computer], secondly make sure the enclosure has no loose connections,
Please note devices like hard drives are real power hogs, just usb connection may not be enough power, You should have a power adapter You can plug to a wall outlet to give extra amps to Your device
Should it power on fully, make sure to go to system details [you go there by ressing a button in "about my mac" little window from the apple logo menu and check under usb listing if it is listed
lastly go to disk utility and check if the drive is visible, if it is not mounted it may need formatting
Jan 13, 2010 | Aluratek AHDU350 USB 2.0 Hard Drive
My PC is not recognizing Aluratek AHDUB250 External hard drive
There is conflit on the drive path.
Try changing the drive path-1st {diverce manager} then {disk management}locate your drive change the drive path
Jul 21, 2009 | Aluratek AHDUB250 USB 2.0 Hard Drive
External HD not recognized
right click on My Computer then go to Manage. select disk management and assign a letter to your external drive. close out and reboot
Nov 24, 2008 | Dell Dimension 3000 PC Desktop
External hard drive making alarm noise and will not load, I tried it on two computers that it has run on in the past. It is an aluratek model AHDUB250. I have around a thousand pics from my receant tour in...
A drive making noise suggests that something physical has gone wrong.  If something happened so that the OS simply can't access your data and there not too much physical damage to the disk, try one of those recovery programs, but one that doesn't attempt to fix the disk, only access the data
May 12, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Aluratek AHDUB250 USB 2.0 Hard Drive Logo
230 people viewed this question
Top Aluratek Computers & Internet Experts
Ed Mac
Brett Duxbury
Brett Duxbury
Are you an Aluratek Computer and Internet Expert? Answer questions, earn points and help others
