vss dead (veh, speed sensor)
A/T 700 codes are transmission errors. so is p17xxx
706 is trans mission range switch open circuited (bad switch or wires)
the scan codes never tell you what part is bad or what to replace.
it tells you ONLY what tests fail. called Monitors.
a Service tech, does this magic,. with tools and meters and gauges and special tests.
you can look up codes here.
http://engine-codes.com/you can go to alldata.com (or get a real honda fsm book)
in the book it covers each code and now to test it and find the truth.
for example they will show you how to find P0501.
by looking at the VSS signal if good, the wires are bad.
if the signal is bad, the sender is bad. using a scope or meter.
good luck to you.
