Question about SanDisk Sansa e250 MP3 Player
Sansa E 250
When you plug in usb , while loading program it says error and call the manufactor. not sure what to do.
Or just wait till the dman battery goes dead and recharge it
Posted on Jun 26, 2008
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
My sandisk e 250 one gb ipod is not detecting in ubuntu 10.04 but is charging
you must follow 5 steps
1) connect ur device to windows xp or windows 7
2) go to sansa website download sansa updater and install it
3) then follow instructions by sansa updater it will then automatically search and install a program for detection of mp3 player on ubuntu install that program its around 16mb .the software will do this you just follow this
4 after completing sansa updater instruction ,go to settings you can now see a usb mode then change to msc mode for detection in ubuntu
5 for detection on windows change to mtp mode
Oct 22, 2010 | SanDisk Sansa e250 MP3 Player
I need help on my Sansa e250, if I plug it to a computer or if i charge and even just merely turning it on, it just turn's on and off, my cousin who gave me my sansa told me that the battery was just...
Remove the back and check and see if the battery isn't fully connected
I put a folded peace of paper and put it on top of the battery and put the back on.
Usb mode is in settings push center button choose between msc or mtp....
MSC will allow you to see the expansion card mtp won't.....MTP shows you your music2_bing.gif folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode make sure your usb 2.0 driver is installedMSC is best reate a music1 folder and put music in there then there is no switching back and forth to mtp msc
Apr 06, 2010 | SanDisk Sansa e250 MP3 Player
PC does not reconize sansa 250
plug it in after you log on to your computer and wait for all the pop ups to go away then plug it in
Nov 25, 2009 | SanDisk Sansa e250 MP3 Player
Delete all current content from sansa E-250 mpc
follw the given steps-
  1. Check to see that the player is in MSC mode by going to the USB mode section in the "Settings" menu.
  2. Plug the SanDisk Sansa MP3 player into your computer.
  3. Click on the "Start" menu.
  4. Click on "My Computer."
  5. You will now see a drive for the device and one for the SD card.
  6. Double click on the "Sansa device."
  7. Select the music file you wish to delete.
  8. Press "Delete" on your keyboard.
    Thanks,
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Nov 18, 2009 | SanDisk Sansa e250 MP3 Player
Blank Screen, Frozen, restarts FAT Error message
hold switch up for 15 seconds, this will reset the dam thing
Oct 04, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa wont turn on
well did u make sure it is fully charged if so den plug it into the computer
Aug 20, 2009 | SanDisk Sansa e250 MP3 Player
Change MP3 from USB to MSC mode
Usb mode is in settings push center button choose between msc or mtp.... MSC will allow you to see the expansion card mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode make sure your usb 2.0 driver is installed
Jun 27, 2009 | SanDisk Sansa e260 MP3 Player
Sansa E250 how do I put songs onto the mp3
Go to My Computer and then look for the Sansa 250 icon there. If it doesn't show up, unplug the USB cord and plug it in again. Once you have the icon visible in My Computer, click on it twice and open it up. To load content, go to wherever you have MP3 files or whatever and use Windows Explorer to copy the content from your computer to the Sansa. You can also manage it through Real Player or other MP3 players (Media Monkey).
Dec 24, 2008 | SanDisk Sansa e250 MP3 Player
I don't know how to load music from the internet to my new mp3
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel1.gif Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data1.gif folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 28, 2008 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
80 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
