Kenmore MN: 110.26822692 Washer has stopped draining water. Has power & runs on other parts of cycle (not on spin). Help ! Charlie
  • 1 more comment
  • dillcc Jul 16, 2009
    Thanks !
    Can you tell me where the solenoid is located ?
    Thanks.
    Seems like that would be where the potential clog might be. Where would the solenoid be located ........... somewhere near the pump ? I'm thinking it is something wrong with the pump or electrical since I can't hear the pump running at all.
    Didn't get all of your message in last comment........"is there" is the end of the message. Please repeat.
  • 534 Answers
Check for blockage in drain hose. Some hoses have a screen type filter that catches lint and peices of fabric to prevent them from clogging your drain.. Also would check to see if the magneto (drain sileniod0 has the required voltage to engage the drain cycle
Posted on Jul 16, 2009
  • 1 more comment
  • david berry Jul 16, 2009
    follow the drain line back towards your washer. Where this drain line connects to the washer that is your animal. Good Luck
    Dave
    if you dont hear the motor running that is the problem the seliniod (?) is there
  • david berry Jul 17, 2009
    sorry that was cut off if the motor isn't running the seliniod will not be working either. You said you couldn't hear the motor coming on. This seliniod is about 2x2 inch square box that has a metal shaft running into it. This shaft actives the drain for the drum once an electrical charge is supplied the box acts like a magnet and pulls the shaft into it activating the draining process. If you do not see this type of box then it is safe to assume the draining mechanism is located in the motor housing itself. In that case the motor will need to be replaced. Good Luck
    Dave
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
Dec 03, 2009 | Kenmore Washing Machines
Washer fill or drain but does not spin
It's not supposed to spin during water fill and draining, if I understand your post.
Charlie
Aug 23, 2009 | Kenmore 44102 Front Load Washer
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
My washer will not go to spin cycle,.
Hi my name is joyce,
first lets try to get the water out of washer, put on drain cycle, after it drains water out take clothes out of washer, then lets see if it will run on spin cycle, it may have to many clothes, if this does not help then you have a transmission problem, this will defenently need a technichan to look at it. if you need I can look in you area and see if I can find you some assistance.
Joyce
Feb 06, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
