Question about Bosch Cooktops
Bosh p/n 166037 - igniter - is obsolete - any suggestions re scourcing or equivalent part please
The electric igniters , all 5, are still firing after the flame is lit. Turning the power off is the only way to stop it. Any suggestions?
Hi jsjone1945,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 22, 2011 | GE Profile JGP636 Gas Cooktop
Hi, We have a GE profile cooktop (JGP975SEK1SS ). Last night, the boiling water spilled on the bottom right burner, so I turned off the stove. But since then every time we turn on the stove, the two...
Hi shadnaz,
A common issue with water causing the problem. I'd suggest following my below Tip on fixing the problem:
GAS COOKTOP CLICKING PROBLEM...
Kind Regards
JEDMEYER1
* If this solution helped you, please rate it
Aug 08, 2011 | Cooktops
The ignition is not firing on 2 gas burners. When it does, it keeps making a clicking noise.
Hi rvaidyhome,
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Aug 02, 2011 | GE Cooktops
I have a GE Monogram cooktop and the auto ignition on once of the burners wont stop sparking. What do I need to do?
Hi go4thnx,
I believe your ignition switches have come in to contact with either water or moisture.
Kind Regards
JEDEMEYER1
Jul 25, 2011 | Cooktops
When I turn on a burner on in the front of the cooktop the nearby burner keeps trying to ignite and makes the "clicking sound"
Hi lmills189,
Kind Regards
JEDEMEYER1
Jul 22, 2011 | Thermador Cooktops
Ignitor is spontaneously igiting
Hi hjaragon,
Kind Regards
JEDEMEYER1
Jul 22, 2011 | GE Cooktops
The gas burner cooktop clicks even when all dials are off
Hi nschulman,
Kind Regards
JEDEMEYER1
Jul 20, 2011 | Magic Chef Cooktops
Intermitant clicking of ignitor while in the off position
Hi justin willi,
Kind Regards
JEDEMEYER1
Jul 11, 2011 | GE Profile JGP636 Gas Cooktop
Obsolete Thermador
Hi Iniro
It is true that thermador has permanently discontinued some of its models - alternative supplier have not beeen identified
Regards
Sep 09, 2008 | Thermador SGS36GS Gas Cooktop
Obsolete Thermador
I am looking for Thermador part # 414-564 and Bosch part # AP2831995. Anyone ???
Sep 09, 2007 | Thermador 37 in. SGSX365 Gas Cooktop
Cooktops Logo
Top Bosch Cooktops Experts
paulcarew
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
