Not blowing cool air
The them is set at 77, but the air blowing out is very cool. It is not hot air, but not as cold as it usually is, and the them says 82. I just changed the filter. What else can I check?
  • 534 Answers
Your coils in the area of where you install your filter could be dirty and not allow proper air flow to cool down the area . Also, you possibly could need to have your system checked from a preventive maintenance view.. A check by a quailfied a/c tech shouldn't cost more than 50.00 and will let you know of potential problems that could save you thousands in repairs
Posted on Jul 16, 2009
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Why does the. Air conditioner blow cold air then hot..
which do you want hot or cold . all blowers blow cold air first for a minute or so . then depending on where thetemp dial is set will be either cold cool or warm or HOT .
Mar 13, 2015 | Cars & Trucks
Kia Sedona- center and third row heating vents blowing cold air
This model has a rear heat/cold blend door actuator. Its an electric motor that moves the duct door from hot to cold. When they wear out, they're usually stuck on the last setting
Nov 13, 2013 | Kia Cars & Trucks
Ac blows cold then hot air
Is the compressor running when it blows hot air ?
Jul 31, 2012 | GMC Sierra 1500 Cars & Trucks
2000 NISSAN 4X4 P/U A/C SYSTEM WILL BLOW COLD WHEN OUTSIDE AIR TEMP IS COOL, WHEN HOT OUTSIDE AIR BLOWS HOT.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
May 17, 2012 | 2000 Nissan Frontier
Blowing out hot air
check for the clogged evaporating coil
Jul 20, 2010 | Sharp CV-P10LC Portable Air Conditioner
My air conditioner is blowing cold then hot air.
Check your thermostat or battery backup or both..change or replace if necessary..
Dec 02, 2017 | Heating & Cooling
Air conditioner not blowing cold air. We put coolant with gauge reading 25 lbs pressure. We think the compressor is coming on. The pipe coming out of the compressor is cool but, the air coming into the car...
Is the air actually blowing into the car?But it's just hot?It sounds like your blower motor is not turning to blow air.you have a fuse,check the switch that controls the blower,and the blower motor it self.
Jul 27, 2009 | Saturn L-Series Cars & Trucks
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
