Question about Frigidaire FRS6R5EMB Side by Side Refrigerator
Tree fell on power lines. power out for 4 hours.
Tree fell on power lines. power out for 4 hours. Refrig lights came back on but not tempature lights
  • 153 Answers
Well u have a problem of power supply get it checked by an expert.
Posted on Jul 25, 2009
Large tree in backyard keeps growing over wires. sent question weeks ago about this and no response.
trees and power lines are your responsibility
you have to trim the branches back from the lines or pay the power company to do the job
If the tree is on private property overhanging power lines on the foot path, the utility company will trim back to fence line or further if the branches are still to close to the lines
you first course of action is to ring the power company and talk about what can be done or if the trees and power lines are all on your property, get in tree lopping specialist and pay to have the job down
Sep 18, 2017 | Garden
While parked a tree branch fell on the truck now it won't start it ran fine before the tree branch fell
A Tree Fell on Your Car: Now What?-Allstate
https://www.allstate.com/tools-and.../car.../tree-fell-on-car.aspx
Allstate... parking lot to avoid door dings," so you can imagine his dismay when a tree ...Gregg did his best to salvage his truck after the storm passed, but the ... If you're the owner of both the fallen tree and the vehicle, your homeowners insurance policy likelywon't ... What steps should you consider when a tree falls on your car?
Will landlord's home insurance pay for tree that fell on my car?
www.insure.com > Ask the Home Insurance Expert
Jun 4, 2014 - If a storm causes a tree at your rental property to fall on your car, don't expect ... Will landlord's home insurance pay for tree that fell on my car during a storm? ... The landlord, thus, won't be found liable by the insurance company and ...damaged if you also knew of the tree's fragile condition and parked by it.
Responsibility for damage caused by falling trees is a ...
www.post-gazette.com/...falling-trees.../2012112...
Pittsburgh Post?GazetteNov 23, 2012 - Pittsburgh Then & Now ... The philosophers wanted to know what happens when a tree falls in a forest. ... and knock branches onto your home, causing serious damage." Coverage ... But if you do the same to your own property, your own auto policy probably won't cover damages to your trees and shrubs.
DOT hits tree, tree branch damages legally parked car ...
Jan 25, 2016 | Cars & Trucks
Husqvarna 362xp Seems to lose power and struggle with felling back cut on big trees,20 inch bar on it,but seems fine when cross cutting big trees,any ideas please
It sounds like a "positional-related" problem, in which the first area I'd look at would be the fuel line in the tank and fuel filter. Hook and fish the line out and examine it (no kinks, cuts, hangs freely in tank) & clean/replace the fuel filter as that is the most likely culprit.
Oct 28, 2014 | Garden
What is the use of felling axes?
The felling axe purpose is to cut across the grain of wood as in the felling of the trees. There are different weights, shapes, handle types and cutting geometries to match the characteristics of the material being cut.
Feb 03, 2013 | Garden
Icemaker works fine but no water at door. Have water at bottom of door at quick connect but not at dispenser.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . There is also , a dispenser heater , pt . # WR49X10173 , which comes with instructions , to keep this grom happening again .
Nov 26, 2009 | Hotpoint HSS25GFP Side by Side...
Over tempature reset keeps beeping
its registering a warm temp, you reset it but when it checks again in 2 hours or so its still seeing a warm temp whichi s why the alrm is going off, id look at the contents of the refrig for signs of defrosting, icecream not hard enough, ice maker not producing and melting, moilk spoiling premature, butter too soft.
Nov 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Tv won't power on
Good day, mochoaaanderpear;
Hitachi has LED’s, green ‘lights’ and a red light to determine what circuit may be the problem; after removing the back of TV, bottom only, plug TV back in and observe which LED’s come on …..BUT most important which LED’s don’t come on; locate and note number, EG; DP37 and etc.
Good luck, big IRISH. Ps let me know.
Jun 03, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
CANNON SURE SHOT 80U
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Jan 22, 2008 | Canon Sure Shot 80U 35mm Point and Shoot...
How do I change the date? I don't have a manual.
Jan 13, 2008 | Canon Sure Shot Z180u 35mm Point and Shoot...
Date and time
Nov 07, 2007 | Canon Sure Shot 80U 35mm Point and Shoot...
Frigidaire FRS6R5EMB Side by Side Refrigerator Logo
76 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
