Cars & Trucks Logo
Terence Bolton Posted on Mar 10, 2016
Clutch repair videio
Is it a easy job out of a garage from ground level
dopenl
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Mar 10, 2016
dopenl
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
12442
Points
17
Depending on the car!
I have done many on the ground/ Axel stands.
So yes doeable, you will need some tools
2answers
What would cause a loud knocking noise?
in the engine --- failed big end or main bearings
Clutch , presure plate and gearbox remove
You need the right equipment and knowledge to do this job there are a lot of cables wires etc that need to be removed before the gearbox can be loosened and removed.
There are also a lot of special tools required and the job is best done on a ramp or pit to gain access.
Trying to do this on the ground would be difficult and very dangerous also the engine needs to be suspended when the gearbox mounts are removed.
It is impossible to remove the clutch pressure plate, plate and hydraulic bearing on the C4 without removing the gearbox.
Take it to a garage/ clutch specialist.
How to replace clutch
man, u jus gotta purchase a repair manual for $30!!...don't know y people r so reluctant about purchasing a repair manual!!...you always get ur money back usually on the 1st repair job!!..buy a repair manual for $30 or pay the garage $300 or more!!
2answers
How can I replace torsion spring of my garage door?
A garage door's operating system is not a simple one. I think you should go for expert's help. take a look at Garage Door Repair Houston TX
1helpful
I've been told that my greabox "is bad and your gears could jam at any time" by a garage today. I'd taken the car in due to a whirring "loose" sound when I change gear but the noise is...
If you have a smoky problem don't bother
with the second trans & clutch opinion
GET RIDE OF IT
Clutch Service $900.00
Trans Issues $2,200.00
Engine Work $2,500.00
Still want to keep it ??
1998 Nissan Altima -Trying to check and see if the clutch on the compressor is or isn't kicking on. On my GMC the pressure switch on the Accumulator is 2 wire and easy to bypass. The Nissan has 4 wires,...
Using a power probe or a test light, you have to check to see if you have power running to the clutch first. If yes, then the wire to the clutch is usually grounded to the compressor itself, so you find it by working backwards from the ground. Hope this helps.
1helpful
The water pump pulley fell off my '93 oldsmobile cutlass ciera S (6 cylinder). Is the pulley a separate part that I could replace? or must I replace the entire water pump? Is that something I could do...
Pulley is bolted to the water pump. If the pump shaft failed you need to replace the pump. If you have a clutch on the fan, and that failed, providing that the pump shaft is not loose or binding and pump is not leaking, you can replace the clutch (don't re-use fan if it bent when it came off) The clutch is somewhat easier to replace than is the pump. Depending upon your level of experience, it's not a really difficult job, but I recommend you get a manual (haynes, chilton etc) to guide you through the job.(too long to write out here). If you run into any specific problem while doing the job, we're here to help.
If it overheated when pulley came off, change the thermostat as well...once overheated therm becomes unreliable.
good luck!!
1helpful
High reving to get the car moving
UNFORTUATELY ITS NOT A EASY JOB TO DO AS YOU HAVE TO REMOVE SUBFRAME TO GET GEARBOX OUT & PUTTING GEARBOX & SUBFRAME IN YOU NEED LINING UP TOOL FOR SUBFRAME.YOU ALSO NEED ACCESS TO A TWO POST RAMP HOPE THIS HELPS YOU.
Replacing a clutch
Hello;
First congratulations on buying a camaro. If you have the clutch replaced, cost is in the $500. range. Can you do it yourself depends on several factors. The transmission weighs around 75 pounds. Do yo have a hoist or going to do it on the ground? Are you mechanically inclined enogh to tackle the job? It is an easy straight forward job if you know what you are doing or can have someone help.
Let me kow if you have other questiions regarding this. I have done a lot of clutchs so I can answer your questions quickly.
Thanks;
Rich
RPM Northwest
6helpful
Clutch replacement cost
8-10 hrs is more accurate, call around to other repair shops and ask what the flat rate time is for a clutch change on your make and model, most clutch jobs run around $600-800.
Top Rover Experts
Thomas Perkins
Thomas Perkins
 Mikey
Mikey
Kardoc
Are you a Rover Expert? Answer questions, earn points and help others
